TortoiseSVN setup question
10 replies to this topic
#1 george seifert
george seifert
  • PipPipPipPip
  • 398 posts
Posted 03 June 2010 - 01:27 PM
We're a relatively small development group. There will probably be at most 3 people (but usually just me) accessing the code. Do you know if it's necessary to have a special server or could we just have the repository on a network drive? If we do set it up that way at first would it be hard to migrate to a server later if necessary?
George
#2 mike5
mike5
  • 159 posts
  • Version:LabVIEW 2010
  • Since:2009
Posted 03 June 2010 - 01:34 PM
George
It's a Subversion question, but anyway... As soon as you have more than one developer you need to access repository through a server. Otherwise you're just begging for repository corruption.
Br, Mike
Close the world, txEn eht nepO.
#3 Biometrology
Biometrology
    Active
  • Pip
  • 11 posts
Posted 03 June 2010 - 02:53 PM
George, you could do this (I did) - but I wouldn't necessarily recommend it.
One of the problems of keeping the repository on a network drive is that any random person can accidentally move, delete or rename the path to them.Posted Image
To move from the shared drive to a server I had to do the following steps (from memory):
Posted Imageexport the repository using Subversion (I had to install it just to do this).
Posted ImageThe very large file resulting then had to be imported into the new repository on the server by one of our IT guys
Posted Image All the working copies then have to be changed to point at the new repositories (using the relocate command)
Posted Image This only works if the repository has not changed since you exported it!!!!
Hope this guides your decision.... Posted Image
Alex
#4 george seifert
george seifert
  • PipPipPipPip
  • 398 posts
Posted 03 June 2010 - 03:15 PM
Thanks guys. Sounds like I better get IT involved from the get go.
Sorry I knew it was a Subversion question (I am using it for LV though), but I knew how helpful everyone is anyway.
George
#5 Shaun Hayward
Shaun Hayward
  • 138 posts
  • Since:2003
Posted 03 June 2010 - 03:47 PM
George
There's a great free (although it also has a paid "pro" version) subversion server called VisualSVN Server (http://visualsvn.net/server/) - it is super easy to modify repositories, etc and even plays nicely with Active Directory if your on a Windows Domain setup.
Shaun
#6 DMC Engineering
DMC Engineering
    Are we there yet?
  • 5 posts
  • Since:2009
Posted 01 July 2011 - 07:31 PM
I was recently looking into this, and it might be worth looking into even if you are a smaller group of people assessing the code at this point in time. Effective use of SCC takes discipline because what is not checked into the repository is not saved. Opening a project several years after the fact to find out that the latest code resided on a long decommissioned computer is not a pleasant experience. It is in everyone's best interest to make sure that code is properly stored in the repository at all key points of the project's lifecycle.
The best way to maximize the effective utilization of SCC is to make it as easy to use for your staff as possible. As a result, we use a combination of two tools to manage our source code. The first is Tortoise SVN, an explorer shell based SCC system which works for almost any project type. The ease of use and concurrent-development options of TSVN have dramatically boosted our ability to collaborate, release and maintain code. By itsef, TSVN is revolutionary if you are coming from an older style of source code control. Paired with Visual SVN Server, the benefits become even more pronounced.
Here is a link for more information: http://www.dmcinfo.c...t-anywhere.aspx
Hope that is at very least, informative!
George
#7 Callahan69
Callahan69
    4 more posts to go.
  • 6 posts
  • Version:LabVIEW 8.6
  • Since:2006
Posted 24 November 2011 - 05:31 PM
Hello,
I am a Tortoise user, but I use the wrong way for my repositories (they are on a network drive, so I do "file:"... accesses).
I'd like to access my repositories from everywhere in the world, using a real server.
I installed Visual SVN as you suggest it, but I did it on MY pc, and I get a "https://nameofmypc/svn/nameofmyproject/" URL, so my repositories are not accessible from anywhere throught the internet.
Does anyone can explain me how can I finally get a URL in the good form ?
I think I need a web server with a domain name, or put my IP in the url, but I don't know how to do that.
Thanks,
Callahan.
#8 Ton Plomp
Ton Plomp
    How many lines per hour? Zero!
  • 1,971 posts
Posted 25 November 2011 - 06:43 AM
Hello Callahan,
I wouldn't use your own server for serious public hosting. There are free (or almost free) hosting options for SVN available.
But if you insist, you need a few things, an domain address that points to your computer's IP-address. Most likely your computer is not directly connected to the internet, but via a router, so you need to set up the firewall or NAT of the router to point port 80 to your internal computer IP address.
If your computer is at work you'll need to consult IT for the exact configurations.
Ton
#9 Callahan69
Callahan69
    4 more posts to go.
  • 6 posts
  • Since:2006
Posted 25 November 2011 - 10:01 AM
Thanks for your answer.
I understand that configuring my own server would be a bad idea.
Can you explain me the "free hosting options for SVN" ?
What is the complete procedure to do that ?
If I use a free web hosting, how create, manage, back-up etc.. the repositories ?
Tortoise is the traditionnal way for the windows subversion client, what is the traditionnal way for free hosting ?
Is this solution adapted to your profesionnal LabVIEW projects ?
Callahan
#10 Ton Plomp
Ton Plomp
  • 1,971 posts
Posted 25 November 2011 - 05:47 PM
There is to the client no difference where the repository is hosted (as long as there is a reliable internet connection), there might be a speed issue.
Every hosting provider has there own set of tools for managing repositories.
Ton
#11 Callahan69
Callahan69
    4 more posts to go.
  • 6 posts
  • Since:2006
Posted 25 November 2011 - 05:57 PM
And what is the top three of hosting providers ?
Google code is in the list ?
