* * * * * 5 votes
LabVIEW, Websockets, and SVG
64 replies to this topic
#61 ShaunR
ShaunR
    LabVIEW Archetype
  • 2,709 posts
Posted 07 October 2012 - 04:38 PM
Hi there!
So I tried this Websocket on a cRio.
The only thing that needs to be changed is the EOF,
I used the \r\n constant instead of CR\LF.
But theres one more problem that I am currently facing,
I cant access the svg file via web publish in the cRio. The svg file looks fine if I access to it via ftp.
But if I put it in the www folder and access via http, it comes out as text instead of graphics.
I tried a lot of method including creating a html file that calls the svg.
So far, none of them worked.
Currently using LabVIEW 2011 and Chrome ver 22.
He also has a website dedicated to this at http://blog.evexiall...=37#comment-54.
Might be worth asking the question there also.
A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort. (Herm Albright 1876-1944).
Founder and general mischief maker on www.lvs-tools.co.uk.
SQlite aficionado and websocket zealot.
If it 'aint in LabVIEW, then you 'aint got a clue!
#62 madtofan
madtofan
    I've come back for more.
  • 2 posts
  • Since:2010
Posted 08 October 2012 - 09:40 AM
my bad.
I didnt notice the mime.types part
so i went into the cRio ni-rt/system/webserver/ folder and added "image/svg+xml svg svgz" into the mime.types file.
now it pops up fine.
thanks! :D
#63 sharkera
sharkera
    One hit wonder!
  • 1 posts
  • Version:LabVIEW 2013
Posted 11 August 2014 - 08:04 AM
Hi smarlow,
I know this is a really old thread, but I am intrigued by the use of WebSockets and LabVIEW.  Lately I found a library that NI released:
https://decibel.ni.c.../docs/DOC-38927 and I found the code to be very similar to yours.  I was just curious if you knew about this ... basically this library combines WebSockets and NI's CVT so that CVT tags get pushed out and exposed through Websocket connections.  Still have write your own UI web code, tho.  There's another package that's fascinating lately: http://labsocket.com/.  This commercial software supposedly "scrapes" your front panel generates a thin-client webpage for you.  Haven't tried it but looks promising.  Cheers!
#64 smithd
smithd
    Active
  • NI
  • 18 posts
  • Since:2011
Posted 11 August 2014 - 11:16 PM
Hi smarlow,
Hey sharkera,
That toolset actually consists of a few things.
The first package, tagwebclient, is a javascript+HTML web page along with some LabVIEW type definitions which are intended to allow you to create new web services which provide tag-oriented data to the web using a standard interface. At present it needs some work, but the basic concept is down. For example, there is a "tag browse" page which requests the available list of tags from a correctly-formatted web service.
The second package, cvt web addon, is a LabVIEW web service which uses the CVT and aims to meet the contract required for the tagwebclient. Originally, these packages were combined but we are interested in making a web service which supports the new tag bus library (which is basically CVT on a wire): https://decibel.ni.c.../docs/DOC-36995
Finally, the cvt web addon does have a sample websocket server. However, to the best of my knowledge it currently just supports sending strings back and forth. It is not used to transfer tag data -- standard labview web service functions are used for that.
Thanks,
Daniel
#65 Jordan Kuehn
Jordan Kuehn
  • PipPipPipPip
  • 367 posts
  • Since:2009
Posted 16 September 2014 - 07:55 PM
I'll bring this back to life one more time.  I'm trying to use the webpanel demo, but I'm getting errors in the browser that suggest that jQuery is not being included correctly in the SVG file.  I've attempted to modify the SVG file to include the libraries, but this generates other errors.  Google suggests that jQuery assumes that it exists in HTML rather than SVG which may be causing the problems.  Is this an issue that others are encountering?  Could this simply be that I have up to date browsers and javascript installed and support broke along the way or am I doing something stupid?  I can navigate to 127.0.0.1:81 in Chrome and it begins downloading data and the VI shows a connection, so I think things are ok on that end.
ReferenceError: $ is not defined webpanel.js:34
Edit//
By downloading jQuery 1.9.1 and changing line 1321 from
if ( !all || !a || !all.length ) {
to
if (!all || !a || !all.length || !a.style) {
as described here I was able to get WP_jQuery.svg to work.  This page suggests it is a jQuery bug that may not have affected older browsers.  Perhaps a new release with the modified jQuery source is in order.
Edited by Jordan Kuehn, 16 September 2014 - 08:23 PM.
The Colex Group
Lead Software Engineer
Certified LabVIEW Developer
