Grey out text
5 replies to this topic
#1 neil
neil
  • PipPipPipPip
  • 410 posts
  • Since:2004
Posted 17 February 2012 - 02:22 PM
Hi GUI experts,
I have a bit of a problem I can't think of a way to solve (other than the obvious solution which I don't want to do).
Basically, can anybody think of a way of displaying a text string that has colouring corresponding to its state. In other words I don't want to change the text of the string, just want to make it "bright" when the boolean state is true, and "lightly greyed" when it is false, see the picture for an example of the "lightly greyed" case.
Now, of course this can be done using VI server calls to the text colour, but I want to avoid that. The reason is I would like this to be part of a bigger cluster with other things, and I want to just, from the BD, write the value to the indicator, so this precludes property nodes.
It is totally not a deal-breaker if I have to go down the property node route, just curious more than anything I suppose. :D
Can anybody think of how to do this without using property nodes?
CLA, CPI and CTM (Certified Tea Maker)
#2 mje
mje
  • 813 posts
  • Since:1997
Posted 17 February 2012 - 02:49 PM
Too bad boolean buttons don't allow different color text based on value, it would allow you to do exactly what you want. Seems you can only change background color.
#3 ShaunR
ShaunR
    LabVIEW Archetype
  • 2,224 posts
Posted 17 February 2012 - 03:18 PM
POPULAR
Turn off the text and use images.
Edited by ShaunR, 17 February 2012 - 03:26 PM.
A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort. (Herm Albright 1876-1944).
Founder and general mischief maker on www.labview-tools.com.
SQlite aficionado and websocket zealot.
If it 'aint in LabVIEW, then you 'aint got a clue!
#4 neil
neil
  • PipPipPipPip
  • 410 posts
  • Since:2004
Posted 17 February 2012 - 03:30 PM
Sneaky! I like it :worshippy:
#5 Yair
Yair
    Extwemely Active
  • 2,645 posts
  • Since:2003
Posted 19 February 2012 - 01:13 PM
You could also vote for this idea - http://forums.ni.com...s/idi-p/1827265
#6 neil
neil
  • PipPipPipPip
  • 410 posts
  • Since:2004
Posted 19 February 2012 - 09:36 PM
I must have missed that one. Thanks!
