FieldPoint IO Point dosen't work in .exe file
2 replies to this topic
#1 Thang Nguyen
Thang Nguyen
  • 230 posts
  • Version:LabVIEW 2010
  • Since:2006
Posted 18 May 2007 - 03:45 PM
I am working with FieldPoint. Everything work fine, until I built the .exe file. When I click on the FieldPoint IO Point I see the browse ... But when I select it there is a pop up window appear for 1 sec then it disappear. I can not select the channel. Can anyone tell me how to fix this?
THank you,
Thang Nguyen
Nothing is impossible, just do it!!!
#2 Thang Nguyen
Thang Nguyen
  • 230 posts
  • Since:2006
Posted 19 May 2007 - 08:12 PM
This is the project to build .exe file, I use only one control which is the FP IO point. I can not open to select it.
I use LabVIEW 8.2.1.
Please check it for me.Highly appreciate for your time,
Thang Nguyen
#3 Ashish Uttarwar
Ashish Uttarwar
    More Active
  • Validating
  • PipPip
  • 36 posts
  • Since:2011
Posted 03 July 2007 - 05:28 PM
Thang,
You need to add a Fieldpoint target inthe project. This will allow you to add cFP channels.
There is a knowledgebase on NI discussing this. You can find it here (http://digital.ni.co...6257241006D7C77).
After you add the cFP in the project, MOVE the "Test.vi" under the cFP and open it. This will allow you to browse to the channels of the cFP.
I hope this helps.
Regards,
Ashish
- Ashish
