Map, implemented with classes, for 8.5
87 replies to this topic
#21 Aristos Queue
Aristos Queue
    LV R&D: I write C++/# so you don't have to.
  • 2,620 posts
Posted 30 August 2007 - 06:11 PM
Quick reply for now on a single point...
QUOTE
What exactly do you mean inside-the-class and outside-the-class.
I mean that for VIs outside the class, they see a coherent "Map" object that behaves dataflow safe in all cases and a set of API functions that act on that map in a dataflow-safe way. But on VIs inside the class, there are calls to member functions that adjust parts of that map in ways that wouldn't be dataflow safe under all conditions, but the conditions are limited such that it works in the cases that are actually capable of executing.
QUOTE(Tomi Maila @ Aug 29 2007, 11:25 AM)
LabVIEW has always been a programming language that one can learn without reading books simply by checking the documentation of each node. Now these particula techniques are not documented anywhere. LabVIEW help doesn't tell much anything. Users are tempted to give these new memory management nodes a try. They may soon use them thinking they understand, but they don't. At least if they are as stupid as I'm. ;) There is simply no way a user can learn these techiques if there is not a very comprehensive introduction to these techiques. This is also true for the most advanced users like the ones here at LAVA.
If enough people disagree, I'll fix the compiler so this doesn't work at all. It's easy enough to detect -- just prevent a class from using any ancestor class from being used as a data member. It is a door I left open, consciously and deliberately, because of this use case.
Part of posting it here is to evaluate whether this should remain part of the language syntax. It would be the work of a few moments to render classes that do this broken. As for the documentation, you're reading it. None of this has been done with LabVIEW until this Map class that I've posted. Its feasibility was only theoretical until I finished it recently.
It's like a manhole cover. Sometimes it's useful to go into the sewer drain, but you can get covered in crap. City work crews could lock down the manholes, or they could just leave the lid unlocked and brave users can descend into the depths. This hole is more dangerous than most of the ones on LabVIEW Street because of the crash issue. You want an example of things that are normally reserved for password-protected VIs that users aren't allowed to look at? This is a prime example.
So, you tell me... should we close this hole in the language syntax?
As for the users being tempted to try the memory management primitives -- yeah, I wasn't really in favor of adding those to the language. They encourage you to care about things that you really should leave to the compiler 99.9% of the time. I know they're useful, but I really think they should've been a separate toolkit -- the license key for them could've been handed out to Certified LabVIEW Developers as a prize when they passed their exams. But it wasn't my call to make. They are in the palettes. And yet, there's not going to be any horn blowing to announce them. There never will be any comprehensive training with these prims -- they're quietly sitting off in one palette, to be pointed out to users by AEs when they reach some otherwise unresolvable issue. And they can be explored by zealous LV users.
Side note... after today, I may not be posting much for the next week or so. Other stuff going on. I'll try to get a more complete answer to Tomi's questions later today, but no guarantees.
#22 Tomi Maila
Tomi Maila
  • JKI
  • 841 posts
  • Version:LabVIEW 8.6
  • Since:2004
Posted 30 August 2007 - 06:40 PM
QUOTE(Aristos Queue @ Aug 29 2007, 07:50 PM)
Actually I've been using recursive data structures from the day LV 8.20 was introduced with some occasional troubles but I actually never knew there was something wrong with them. One of my most challenging projects that required modifications to a graph constantly failed when I was developing it with 8.20. I though it was due to LV 8.20 bugs, but now it appears to me that it may also have been that I failed to do the things the correct way. But the fact that our team has been extensively using recursive LVOOP data structures means that if you close the syntax from the language, then the programs that we've spends hundreds or even thousands of hours, won't work. I don't think closing this hole is anymore an option. I was rather saying that now that the hole is there you should document how to use it. And make the documentation comprehensive.
I really appreciate if you would. We are just working for a major project that needs to use recursive data structures. I simply need to understand what's going on.
#23 Jim Kring
Jim Kring
    packages everywhere!
  • JKI
  • 1,901 posts
  • Since:1995
Posted 30 August 2007 - 08:04 PM
QUOTE(Aristos Queue @ Aug 29 2007, 09:50 AM)
It seems to me (and I still don't understand everything that's going on here, fully) that the feature which should be removed (if we have to make a choice) is the Swap Values function rather than the ability for a child object to have a parent object in its private data. It seems that the "problem" is that the behavior of swapping values in memory is a function of how LabVIEW stores data in memory and this is something that we should generally not have to care about in the domain of dataflow.
#24 gb119
gb119
  • 256 posts
  • Since:1995
Posted 30 August 2007 - 08:59 PM
QUOTE(Jim Kring @ Aug 29 2007, 07:43 PM)
I have to say that this whole thread just makes my head hurt ! The swap Values primitive reminds me of the fun I had when I wrote my own CIN to manipulate the string handles in a string array - all of a sudden I noticed backwards propagation of data :unsure: !
Now I just need the new LV 8.5 DVDs to make their way from the darker recesses of my university to me...
Gavin Burnell
Lecturer in Condensed Matter Physics
School of Physics and Astronomy
University of Leeds, UK
http://www.stoner.le...ac.uk/people/gb
#25 orko
orko
  • JKI
  • 577 posts
Posted 30 August 2007 - 09:10 PM
QUOTE(Gavin Burnell @ Aug 29 2007, 12:38 PM)
You're not the only one, Gavin. I'm trying to keep up...but there's a lot to digest!
http://forums.lavag.org/index.php?act=attach&type=post&id=6803
Joe "orko" Sines
#26 Aristos Queue
Aristos Queue
  • 2,620 posts
Posted 31 August 2007 - 12:53 AM
QUOTE(robijn @ Aug 29 2007, 10:21 AM)
Gee, you get into a lot of problems only implementing something simple as a map structure...
Wrong lesson to take away from this. The actual lesson is, "Wow, AQ coded a Map class in just three hours that is clean, efficient AND dataflow-safe without introducing the semaphore/mutex locking mechanisms that reference classes would've required."
QUOTE(orko @ Aug 29 2007, 02:49 PM)
QUOTE(Gavin Burnell @ Aug 29 2007, 02:38 PM)
When you live on the cutting edge, you don't get documentation. ;-)
And now, let's see if I can get a few of Tomi's questions answered:
Question 1: Can I get more details about the "simple" Swap in the insert case?
Tomi asked for further details about the "simple" case where we swap in data into the Map during an insert... He gave some examples of differences in behavior that he sees from the Show Buffer Allocations tool when using the Swap prim with different data types. I'm not sure what he saw exactly, but here's a more detailed explanation of my code:
Suppose you have a cluster containing a string. You can unbundle, append to the string and bundle back into the cluster. LV doesn't make a copy of the string because it knows that the result is going back to the same place as the original data. Thus the unbundle terminal is said to be "inplace" to the bundle terminal.
But, if you unbundled the string, appended to it and then sent that string somewhere else, without putting it back in the bundle, LV would make a copy of the string. The data isn't coming back to the cluster, so it cannot share memory with the original cluster because the original cluster needs to continue its execution with the unmodified string value.
Now, consider those two concepts with respect to the Map class. The Map has a piece of data in location P. The new node being inserted has a piece of data at location Q. There are downstream terminals X and Y:
http://forums.lavag.org/index.php?act=attach&type=post&id=6806
Position P would like to be inplace to position X. But if I have new data coming into the cluster AND I need to have the original cluster available for writing, then LV has to make a copy of the data at P. Further, the data that is in Q is being moved into X, but those two memory locations cannot be made in place to each other because they are part of different allocated clusters in memory. So we also make a copy of Q. This is the case of the Unbundled data not going back to the original Bundle node after being modified.
Using the Swap primitive avoids both copies. Instead of copying data out of the cluster and sending it somewhere else, we're now modifying the value in the cluster. How are we modifying the value? We're Unbundling data, then exchanging the value in that memory location with the value at another memory location, and then the wire is going back into the Bundle node. Thus LV knows not to make a copy of the data at the Unbundle node.
QUOTE
1. So my first very simple question is what exactly does Switch Values node and In-Place Memory structure do? Why do they behave differently for different but apparently similar data types.
I have no idea what you're seeing. The class and the cluster should behave identically in the cases you're describing. Please post a VI.
QUOTE
2. How can I know if an operation really happens in-place or not if it's such a crusial thing when manipulating hierarchical data structures.
The Show Buffer Allocations tool. And it isn't crucial, just more efficient. Yes, there is a difference. The Insert function will work without using the Swap, just with less efficiency. Nothing in LV was ever designed to do what I've done with Map. It is a coincidence arising from a thousand different design decisions that this is even viable.
QUOTE
3. In-place memory structure is a rather intuitive thing when you look at the examples of its usage in LabVIEW help. However when you make a subVI call inside in-place memory structure the things get more complicated. How does the subVI know that it needs to operate in-place.
The subVI doesn't know. The subVI is compiled with its own inplaceness. If it doesn't preserve inplaceness across outputs, then the caller will copy the output back into the original buffer. There aren't any references.
QUOTE
If we just don't use in-place memory structures and don't mind of making copies, will we be able to use hierarchical data structures such as binary tree without any tricks and risks of interfering parallel wires?
Honestly, I'm not sure. But I believe that the natural dataflow expression of LV will kick in and make creating the tree impossible.
QUOTE
QUOTE
The node that we're going to delete has the left and right subtrees as member data values. When the deleted node reaches the end of its wire, it will disappear from memory AND WILL TAKE ALL OF ITS MEMBER DATA WITH IT.
Haven't we used the Unbundle node to tell LabVIEW that we are going to use two of the data members, Left and Right in this case? Was the problem that if we didn't use Swap Values nodes to write dummy values l and r to the original object X(L,R) private data, LabVIEW would need to make data copies of the Left (L) and Right ® in order to be able to remove original object X(L,R) from memory? And it wouldn't be an in-place operation any more and we would loose the efficiency.
You got it. If we don't use the Swap primitive, then LV will kindly make a copy of the left and right subtrees for us so that we have independent copies separate from the node being deleted.
QUOTE
Exactly when would X(L,R) disappear from memory?
Whenever the wire that the data is sitting in next executes and new data on the wire stomps on the old data.
QUOTE
How do you know when is LabVIEW going to optimize copies incorrectly either in LV 8.5 or any of the future versions? I guess this is an undocumented issue... How would LabVIEW incorrectly optimize the code in this particular case?
Let me be very clear here: If I do not wire the output of the Unbundle node, LV is correct to optimize out the Bundle node. Every rule of dataflow says that the execution of that bundle node should not be necessary -- there's nothing downstream from the Bundle node to need the data. Remember, we're violating dataflow here -- we're saying that we need LV to change the value on a wire even though that wire isn't going anywhere because the memory is actually shared with items that are going on down the wire.
How will this keep working in future LV versions? Don't know. In fact, I'm pretty sure that LV's compiler will eventually be smart enough to optimize this out unless I deliberately put something in to keep this working. I'm not entirely sure that it should keep working. By many arguments, the code I've written for the Map is a bug that should be fixed, probably in 8.5.1. This bit of magick arises as the confluence of multiple features, and I've posted it here to see what everyone thinks. I see a certain elegance to it, but this may be the same romance a moth feels for a flame.
QUOTE
So what exatly as happened here. We have had four handles (pointer to pointer) for LabVIEW objects LH,RH,lH and rH. The handles themselves remain in the same addresses but the pointers the handles refer to get exchanged. So LH that has originally referred to a Lp to L. Now refers to another pointer lp to l. Am I right or wrong here?
Completely correct.
QUOTE
How do we know that in a future version of LabVIEW this trick will not be optimized as a no-op?
See previous comments.
QUOTE
Actually to complitely understand these things, I'd need more examples of what I shouldn't do and what actions are not allowed rather than what actions the correct answers. I need to ask this one more time. If I don't try to do things in-place, will I still have risks of crashing LabVIEW or something similar when I modify hierarchical data structures?
I honestly am not sure. I tried to get people -- both inside NI and outside -- to work on this problem before release. And I put it in the white paper after release. Everyone got this blank look on their faces and responded with comments like, "I'm not really sure what you're even talking about. I think I'd need to see a working situation to be able to help." So, now everyone can see the scenario that I'm talking about.
If we are going to see a problem, it will definitely show up in the graph case. If the graph can be built -- which I'm not sure is possible -- but if it can, the bug, if it exists, will have to come to light.
#27 Tomi Maila
Tomi Maila
  • JKI
  • 841 posts
  • Since:2004
Posted 31 August 2007 - 09:32 AM
QUOTE(Aristos Queue @ Aug 30 2007, 02:32 AM)
I was unable to replicate what I saw yesterday. I'll post a VI if I can replicate the weird behaviour I saw.
If we take a look at your example class method below, I don't actually see how this VI is an in-place VI. The input buffer and the output buffer are clearly different. Or in other words, the output buffer is not a modified version of the input buffer. So how does LabVIEW interpret this VI to preserve inplaceness across outputs?
Posted Image
Dataflow and functional programming are very similar in concepts. Actually dataflow can be considered to be a subset of functional programming. And functional programming has always allowed this kind of data structures and their manipulation in a very efficient and easy way. So I don't see why LabVIEW in principle couldn't do this. As I already said I've used recursive data structures before in LabVIEW in this particular way you used them now but without new memory management nodes and structures. And they appear to work somehow.
To proove myself right here, I attach a version of AQ's map where all the in-place tircks are removed. And it appears to work. This is perhaps what has confused me the most in this thread. I've used these kind of memory models for LVOOP for ages (1 year) and they have appeared to work. Now AQ has given a message that actually they may not work or they are not intended to work. This has really confused me. Especially when I don't understand why these shouldn't work. I still don't see what is the catch why these shouldn't work.
http://forums.lavag.org/index.php?act=attach&type=post&id=6810
I actually meant why did you have those copy always nodes there. You said that you had them there to avoid incorrect optimization. What kind of incorrect optimization could LV do?
So to write future proof code, avoid relying on the memory model or compiler optimizations or in-placeness.
#28 robijn
robijn
  • 172 posts
  • Version:LabVIEW 7.1
  • Since:2002
Posted 31 August 2007 - 12:56 PM
QUOTE(Aristos Queue @ Aug 30 2007, 01:32 AM)
3 hours, that's quick !
I like the consistency that you basically say "we have dataflow, now we just need to flow efficiently". So just make sure that the data arrives at the correct place in a single time, without accidently generating copies. A copy can probably not be prevented everywhere. And it is tricky: can you guarantee the efficiency when it's embedded in a larger application ? I.e. will the tree not become slow because of the way the tree is used in the app requires LV to make copies of the tree when a tree manipulation method is called ?
Oh BTW, I think a user should never need to think about locking anyway (unless he wants something unusual). Read back my short story on multi-level locking (which works, proven). But that's of no relevance now. But you also still have the locking requirement: if you call a tree manipulation function from two places at the same time, you would still need to lock the entire tree to prevent one mutation to get lost.
:) I think I know some fatal attraction
Joris
#29 Tomi Maila
Tomi Maila
  • JKI
  • 841 posts
  • Since:2004
Posted 31 August 2007 - 01:07 PM
QUOTE(robijn @ Aug 30 2007, 02:35 PM)
No you wouldn't need locking. If you call tree manipulation from two places at the same time, you would manipulate two different trees.
#30 LAVA 1.0 Content
LAVA 1.0 Content
    <customize this text>
  • 2,827 posts
  • Since:2009
Posted 18 September 2007 - 09:59 PM
QUOTE(Aristos Queue @ Aug 28 2007, 11:24 PM)
There are points in this graph where we are modifying a value on one wire which results in a change in value on another parallel wire.
Could you please highlight where this is going on, because I'm not seeing the trickery.
#31 Val Brown
Val Brown
  • PipPipPipPipPip
  • 702 posts
Posted 18 September 2007 - 10:51 PM
Yes.
I'm all for "openness" and "accessibility" and I've enjoyed my days of hacking deep in the bowels of a variety of language constructs but I think this is really not consistent with LV, at least as I understand LV and as far as I understand what you're presenting in your example.
All of my objects are byval
#32 jaegen
jaegen
  • 152 posts
  • Since:1998
Posted 18 September 2007 - 11:43 PM
QUOTE(Val Brown @ Sep 17 2007, 02:30 PM)
Yes.
I have to respectfully disagree ... if only because I've already used this trick in (soon to be) running code :D
Jaegen
#33 Val Brown
Val Brown
  • PipPipPipPipPip
  • 702 posts
Posted 19 September 2007 - 01:10 AM
QUOTE(jaegen @ Sep 17 2007, 03:22 PM)
Jaegen
I understand that but, from a slightly different perspective, you make my point (implicit as it might have been in that last post but obvious in others). It's possible (likely?) that this feature may be removed -- seen as a bug and eliminated. If that happens what will happen to your code?
Part of my trust in LV is that I KNOW what will and will not be there -- IF I stick with the fully documented features. I can and will -- and have! -- gotten support on them from NI when "something's changed" or "not working" and, as a developer, that reliability is of paramount importance. My days of chasing the "latest build of" some Unix-variant are LONG OVER, and I really don't want to get into THAT kind of stuff in re: to LV.
I understand -- others have different perspective, different styles, different uses and different tolerances for doing that kind of dance -- and that's fine. But the question WAS asked and I've just given my perspective, FWIW.
#34 Tomi Maila
Tomi Maila
  • JKI
  • 841 posts
  • Since:2004
Posted 19 September 2007 - 10:12 AM
QUOTE(NormKirchner @ Sep 17 2007, 11:38 PM)
I second this request. AQ, could you please explain where do you think modifying a value on one wire which results in a value change on a parallel wire.
#35 LAVA 1.0 Content
LAVA 1.0 Content
  • 2,827 posts
  • Since:2009
Posted 27 September 2007 - 09:29 PM
Ping....
AQ.. We're waiting.. Are you busy rolling out 8.5.1?
#36 LAVA 1.0 Content
LAVA 1.0 Content
  • 2,827 posts
  • Since:2009
Posted 02 October 2007 - 05:07 PM
Another thing that just came up, is in the CompareKey.vi.
Each of the comparison items needs to be a compare aggregates rather than elements.
This needs to be changed if the data type of the key becomes anything other than a scalar.
Any reason not to?
<edit>
Another item that bubble sorted to the top was the input/output array in 'In Order Fetch Keys' needs to be an array of the the key data type rather than just an array of strings.
#37 Aristos Queue
Aristos Queue
  • 2,620 posts
Posted 02 October 2007 - 09:32 PM
The delay in replying to all the points here is a) I've been out of the office and b) I got a new computer that can build LV really really fast so I no longer have huge pauses during my day to check and reply to LAVA. I will return to this project, but it'll probably be a bit. I do want to get answers posted to the various questions, but this is sort of an ongoing side project rather than mainline work, so it keeps getting deprioritized.
#38 Jim Kring
Jim Kring
  • JKI
  • 1,901 posts
  • Since:1995
Posted 02 October 2007 - 09:43 PM
QUOTE(Aristos Queue @ Oct 1 2007, 01:11 PM)
Maybe we should all pool our money together to get you a slower computer :P
#39 LAVA 1.0 Content
LAVA 1.0 Content
  • 2,827 posts
  • Since:2009
Posted 03 October 2007 - 12:46 PM
QUOTE(Jim Kring @ Oct 1 2007, 04:22 PM)
No need to raise funds, I'd gladly trade my computer for his ;)
Aristos, is it an Apple or a Dell?
#40 Aristos Queue
Aristos Queue
  • 2,620 posts
Posted 16 October 2007 - 12:05 AM
Earlier, I wrote this: QUOTE
That statement is FALSE. I made this statement because I really believed that was what was happening in the diagram. When everyone started asking, "Where is it?" I went back to study the diagram in detail, and had to think about each and every wire branch, and I realized I was wrong. I am sorry for leading you about on a wild goose chase.
I said that use of a parent class in the child class object leads to a hole in LV's dataflow safety. I now retract that statement. There's still something at the back of my head nagging at me that a hole exists, but obviously the Map class doesn't demonstrate it. For now, assume the hole doesn't exist and this was just the fevered worrying of a developer who has spent too many years staring at LV class inplaceness and has become paranoid that some data-copy-bug is actively stalking him. At the moment, we have no known issues with this. Everyone who said, "I don't see why this should be a problem" was correct.
I also need to correct one other point about Always Copy primitive:
This error results from my own poor understanding of a new LV feature. In the original posting of the Map class, I used some Always Copy primitives to force a copy of the constant's value before wiring it to a Swap primitive. This turns out to be unnecessary. Since the Swap prim is not something that modifies values, I thought that the swap would be inplace with the instance coming out of the constant, and thus would cause problems for the constant. Turns out that LabVIEW is smarter than that and the Swap prim will make a copy rather than stomp on the constant's value. So the Always Copy prim is not needed.
The rest of my comments -- the need for the Swap prims, etc -- appear to be correct.
Now, on to the rest of the questions...
QUOTE(Tomi Maila @ Aug 30 2007, 03:11 AM)
I have decided that I didn't explain some aspects of this very well. Specifically, Tomi posted a version of the Map class with all the inplaceness tricks removed, which works fine, and he wanted to know why the inplace tricks are needed. So I have created a MUCH simpler example: the Linked List.
Download File:post-5877-1192399595.zip
This is a linear list of data, where it is easy to append to the start of the list without ever reallocating all the existing entries. To access items in the list, you have to traverse down the list -- there is no direct access the way there is with an array. I've gone with a very flat hierarchy for implementing this example so that the bare minimum number of VIs exist.
Just as with the Map, the key bit of magic is a child class that uses its parent class in the private data cluster. In this case, the parent class is Root and the child class is Node.
There are only four operations currently defined on the list:
  • "Dump to string" allows the list to be shown as a string for debugging (so you can evaluate whether it is working right or not)
  • "Insert at front 1" is one implementation of inserting at the front of the list
  • "Insert at front 2" is a second implementation of inserting at the front of the list; compare the two implementations
  • "Insert at index" walks down the list to a given index and performs an insert at that point
If you open Demo.vi you will see two link lists, one being inserted using version 1, the other being inserted using version 2.
Ok... so let me try to deal with a long list of questions that have been raised by the Map class. To begin with, the Swap block. Here are the block diagrams for LinkedList.lvlib:Node.lvclass:InsertAfter1.vi and LinkedList.lvlib:Node.lvclass:InsertAfter2.vi. (I used red text so you could see there was actually a difference in those two long names!)
Posted Image
Posted Image
In each picture, there's a point marked "A". In version 1, at point A, we make a full copy of the entire list. The information in the cluster is being moved out of one cluster and into another cluster. So LV decides there has to be a copy made so that the two clusters aren't sharing the same data. This defeats the purpose of the LinkedList which is supposed to do inserts without duplicating the list. In version 2, at point A, we use the Swap primitive, new in LV8.5. We take a default Root object and swap it with the contents of Next. Now the contents of the Unbundle are free to be put into a new cluster without duplicating all that data.
Tomi: Does that make sense?
QUOTE(NormKirchner @ Sep 26 2007, 03:08 PM)
I'm confused as to why it is necessary to have the map node methods if they are never used, why not just have them at the branch node level?
The Map Node class is the parent for both Branch Node and Leaf Node. As such, it has to define the interface that both of the children classes must match. Map Node defines the API, and then Branch and Leaf implement it. In the simpler Linked List example, I have done away with the base case. I only have Root and Node, rather than a common parent for each of them. This decision not to have the common parent is a bad architecture decision in many cases because now if I want to have behavior on Root that does not apply to Node, I have no obvious place to put such code. As hierarchies get deeper, such decisions can lead to all sorts of weird hacks.
QUOTE(NormKirchner @ Oct 1 2007, 10:46 AM)
Any reason not to?
If the data type changes from String to LabVIEW Object (as I intend to be able to do in the next version of LV), then Compare Elements will still work just fine -- a class is a scalar as far as any operations on the class are concerned. The fact that there is data bundled together underneath to implement that scalar is hidden away. Note: Do not take this comment as a reason to believe that we'll have class comparison working in the next version of LabVIEW. I may intend this happen, but then, I intended to have classes in 8.0, and we see what happened there...
QUOTE
Yes. I missed that one.
Ok. I think I'm caught up on the backlog of questions on this thread. If there are any I missed, please repost them.
