CONFIGURING WINDOWS SDK FUNTIONS IN LABVIEW
40 replies to this topic
#41 rolfk
rolfk
    LabVIEW Aficionado
  • 2,045 posts
  • Since:1992
Posted 19 November 2011 - 09:43 AM
Is this code available? The link does not work. Please?[/left]
The code as posted in the diagram won't work at all. You can not emulate an embedded fixed size array in a cluster with a LabVIEW variable sized array at all. Instead you have to use a cluster which contains the same amount of elements of the same datatype, to match the fixed size array.
So a GUID is really a cluster of type { uint32,uint16,uint16, {uint8,uint8,uint8,uint8,uint8,uint8,uint8,uint8}}
