[Discuss] Example - Create Polymorphic VI
index.php?app=downloads&module=display&section=screenshot&id=53
Name: Example - Create Polymorphic VI
Submitter: LAVA 1.0 Content
Submitted: 03 Jul 2009
Category: VI Scripting
LabVIEW Version: 7.1
Version: 1.2.0
License Type: BSD (Most common)
Potentially make this available on the VI Package Network?: Yes
Copyright © 2006, Chris Davis
All rights reserved.
Author:
Chris Davis
--see readme text for contact information
Description::
This VI uses scripting to create a new polymorphic VI that contains the methods for creating any type of numeric control on a VI's diagram.
This VI is designed to help a newbie learn some of the basics of LabView scripting. As well as serve as a tool to make scripting easier to code.
Code was created and tested using LV 7.1.1 Code should work in higher LabView versions, but has not been tested there.
Version History:
1.2.0:
Added code to make polymorphic VI's icons match thier intended numeric type.
Fixed a bug where an error 7 would occur because the polymorphic VI doesn't exist on the users machine to be deleted.
1.1.0:
Re-release of code as LV 7.0 for more universal compatability. Changed code slightly to read empty polymorphic VI from disk, instead of using a constant on the diagram.
1.0.0:
Initial release of the code.
