Programming a control
Bug
Dear LabVIEW Architects,
Please help me with my situation. I want to programmitically generate a Control on the front panel.
How can I do tihs?
Regards,
bUg
You can only do that at edit time (not at runtime) and if the VI on which you want to create a control is not running, use scripting for this, see here.
Another solution that can be a workaround at runtime is to hide/show your control, that means you have to create all your controls at edit time though..
To hide/show a control, right clic on it, select "create >> property node >> visible" and link either true or false.
Hope this helps
  • 2 months later...
