Unit Test Frameworks: NI vs JKI?
Daklu
I'm looking for information on the differences between JKI's and NI's unit test frameworks. What advantages does NI's UTF offer over JKI's? What disadvantages?
The BIG difference is one is free and the other costs $1500. I'm looking for other, not so obvious differences. I've used JKI's UTF enough to be comfortable with it; I've not used NI's UTF.
Edited by Daklu
I did compare both by webcast only. I would use the JKI one, not only due to the price.
Using the NI UTF gives you support and a 'ripe' product. But it's not counting that much as JKI will also give you support thru LAVA and as it is based on xUnit, the core is rock solid. And work will continue...
Why I prefer the JKI one is actually that it seems more light-weight. If I do test driven developement, I should (my opinion) code/design for easy testing (which theoretically will make 'good' code). And I want little effort to define the tests.
Turning the coin, NI UTF seems to give you more features for comparison of actual and required output, as well as to check code coverage.
Felix
Here's my heavily-biased weigh-in (disclaimer: I'm on the team that created VI Tester):
I haven't used NI's UTF (but I've seen it demo'ed). It seems to have great features for knowing whether you are testing 100% of your code and need reports to prove it.
Of course, I have used JKI's framework, which is great if you're interested in using a proven software engineering architecture (xUnit) for software testing that's implemented in LabVIEW, for LabVIEW developers, by LabVIEW experts who use it themselves to write and test commercial software products written in LabVIEW. With VI Tester, writing unit tests is fun, since all your tests are written in LabVIEW. This also means that you can reuse code within your tests, and employ object-oriented techniques in the design and implementation of your tests.
JKI uses VI Tester for testing all the software it writes and we're going to keep making improvements over time, including possibly integrating it with other products like VIPM's package builder (JKI currently uses VI Tester to automatically run unit tests on all our VI Packages [software reuse libraries] during the build process).
Update: I'll also add that there is a wealth of information (book, websites, etc.) on xUnit, including: test architectures, design patterns, best practices, tutorials, etc. This means that there's a wealth of training materials that apply almost directly to how to use VI Tester.
Thanks,
-Jim
This is a great topic and I would love to hear everyones experiences with both toolkits.
We get the UTF for free so price isn't an issue. I have been playing with the UTF a lot lately as well.
Is someone from NI able to comment too?
Keep this thread going...
Edited by jgcode
I sometimes wonder if you should get out a little more :P
I thought that everyone uses LabVIEW because it's fun :)
Thanks for all the feedback. It sounds like NI's UTF is geared more towards regulated industries where traceability is required. I'll recommend we adopt JKI's UTF and spend the money elsewhere.
Saving your money to spend elsewhere is a great idea (BTW, VIPM Enterprise is going to be released very soon ;))
Cheers,
Well, yes and no - the unit test framework paradigm is a little different to the xUnit paradigm, but the NI toolkit can help with both test-driven development and it can produce regulated industry artifacts. Also, the NI toolkit doesn't require you to write code (except for setup and teardown, which, essentially, almost every test needs).
I don't know your situation fully, but that sounds wise.
Maybe a little off topic. Does anybody just use TestStand for there unit testing? If so, do you have any recommendation or caveats.
Ben Hysell has written some awesome articles related to unit testing and LabVIEW. One of the articles talks about using TestStand for unit testing:
http://www.viewpointusa.com/newsletter/2009_january/newsletter_2009_jan2.php
He also wrote some great articles about using JKI VI Tester in the same article series here:
http://www.viewpointusa.com/newsletter/2009_february/newsletter_2009_febtdd.php
http://www.viewpointusa.com/newsletter/2009%20March/newsletter_2009_Mar.php
I highly recommend these articles!
http://www.viewpoint...r_2009_jan2.php
http://www.viewpoint...2009_febtdd.php
http://www.viewpoint...er_2009_Mar.php
Excellent, thank you for these links!
