Choosing a DAQ
Eugene
most digital outputs are 5 V i Believe.
It also depends on how much current you need to supply. A USB-6008 might work for you if you dont need a lot of current.
Otherwise I would go with a USb Compact DAQ chassis (since it is powered), or if you need the 3 V only, you might need to go with a compactdaq relay module and feed 3 V through it.
