Pass data via user event with reference or actual data?
Sorry, I'm sure this is covered somewhere, but a quick search didn't find it.
I need to send data from one loop to another. I'm going to generate a user event so the second loop can use a dynamic event to respond to the incoming data. Is it better to send the actual data (which consists of a few clusters with about 10 components in them) or references to the clusters?
George
George
If by "references" you are refering to control references, then pass the data.
Ben
George
Just out of curiousity, but why would you think about sending references to the clusters instead of the actual data itself? It just seems kind of complicated to send the references.
Sending the reference could give you more control - you could send different references at different times. Also, you might want to manipulate more than the data (properties for example). But I agree with PaulG. - if it's always the same cluster and you only want to work on the data, then just send the data.
I'm not sure why you say it would more complicated to send the references. Just right click on the cluster to create a reference and send that. It seemed a little cleaner.
I wasn't sure which way would be faster, create fewer data copies, etc.
George
George
Mot much in it really. Labview nowadays creates copies of things if there is a Y in the day and you've just exhaled. The main advantage of data over refs is that data is much easier to debug since you can probe it directly to see the data.
George
The primary benefit of passing the data directly as opposed to using references is that you avoid race conditions. Once you pass the data via a reference you introduce the possibility of race conditions in your application. They can be very difficult to track down and debug.
