W32/Virut.AI!Generic virus detected in LV2009_ENG_32.exe
OK, I think this is a false alarm but I I think this needs to be investigated.
I downloaded LV2009_ENG_32.exe from the standard download and evaluate LabVIEW link
https://lumen.ni.com/nicif/us/lveval/content.xhtml
However when I run the downloaded file "LV2009_ENG_32.exe" through F-PROT virus scanner I get the following virus detected
See the following report generated by F-Prot
-----------------------------SCAN REPORT-----------------------------
F-PROT Antivirus for Windows
Antivirus Scanning Engine version number: 4.5.1
Virus signature file from: 11/4/2009, 3:23 AM
Scan name: [Custom Scan]
Path to scan: C:\Temp\LV2009_ENG_32.exe|
Normal scan
Also scan: Inside subfolders, Compressed files, Streams
Scan started: 11/4/2009, 5:25:21 PM
[Found virus] <W32/Virut.AI!Generic (not disinfectable)> C:\Temp\LV2009_ENG_32.exe->(ZIP)->Products/MDFSupport/MDF/MDFSupport1.cab->misetup.bin.F5D87C60_CF9D_4AC4_8480_40189BD11225
[Contains infected objects] C:\Temp\LV2009_ENG_32.exe
[Quarantined] C:\Temp\LV2009_ENG_32.exe->(ZIP)->setup.ini
Scan ended: 11/4/2009, 5:47:35 PM
Duration: 0:22:13
Scan result:
Scanned files: 1
Infected objects: 1
Disinfected objects: 0
Quarantined files: 1
I've scanned the file through AVG but that particular variant of the virus doesn't appear in AVG's database.
I've tested this on a clean uninfected machine, can someone else verify this if possible?
If NI could also just confirm this is a false alarm as well
It quarantined an INI file? Definitely a false alarm ... though how it came to be recognized as a virus is perplexing.
Yeah, definitely
but it seemed to have issue with this file as well.
