Trick for conditional array filling
Bobillier
Hi
I just want proposing you a trick for conditional array filling with feetback node . Perhapse lot's of you know that , perhapse not.
Eric BOBILLIER
Exempl in LV2009
Hi Bob
Cool trick!
(Although in this case you have used a while loop)
I personally prefer OpenG Conditional Auto Indexing Tunnel over preallocating arrays.
All the performance, non of the hassle :P
Have you seen this VI?
Hi Bob
Cool trick!
Hi JG
Yes it's true, the limitation of this solution is than there isn't any memory preallocating and for this reason it's better to use it with small size array.
Yes i know OpenG Conditional Auto Indexing Tunnel , but with it you must before have one booleen array (elements to keep)to filter the array in).
Perhapse it will be interesting that you show us, how you made the same exempl ( even array) with OpenG Conditional Auto Indexing Tunnel . wink.gif
Hi JG
Certainly my good man.
Attached is an example project that includes benchmarking for building an array:
  1. From the front
  2. From the back
  3. Preallocating memory first, then taking subset
  4. Using the OpenG array
I get difference performance on single core vs dual core.
Unfortunately this example includes keeping odd numbers I hope that is ok! :P
14 Build Array.zip
[LabVIEW 2009]
Thanks JG
You are right again , my solution is really bad for speed, 5.3s for 100000 points. Better than "add to front" but worst than the others.
Finaly it's bad trick :wacko:
If i compare with your buildArray_reverseArray.vi (who are like the classic solution in my previous post), i obtein a 18ms of time versus 5.3s :frusty: . I don't know why normally those two solutions don't preallocate memory.
If we thinks that feedback Node is not equal to shift register, we have a good exempl of why :cool:
I send you my test vi, perhapse you can add it to your bible of filling array, like exempl to not use ;).
Bye
Eric
buildArray_FillingArray with feedback node.vi
Edited by Bobillier
