[Discuss] GetSnippet
index.php?app=downloads&module=display&section=screenshot&id=118
Submitter: jcarmody
Submitted: 23 Dec 2009
File Updated: 03 Jan 2011
Category: *Uncertified*
LabVIEW Version: 8.2
License Type: BSD (Most common)
GetSnippet RCF Plugin v1.0.0
Copyright @ 2009, Jim Carmody
All rights reserved.
Author: Jim Carmody
LAVA name: jcarmody
Contact Info: Contact via PM on www.lavag.org
LabVIEW version:
Created and tested with LabVIEW 8.2
Dependencies:
JKI Right-Click Framework
LabVIEW 8.2 or higher
Description:
The Code Capture Tool 2.0 can create a VI snippet in LV versions as old as 7.0; this plugin lets you extract them in versions 8.2 and above. Standard conditions apply - you won't be able to extract a snippet that was created in a newer version of LabVIEW.
Instructions:
Extract the zip file into [LabVIEW]\Resource\JKI\RCF\Plugins\GetSnippet and restart the RCF framework. Once installed, select a snippet, activate the RCF and select GetSnippet and your decoration will be replaced by the underlying code.
Known Issues:
Hardly anybody makes snippets in anything except LabVIEW 2009. :( The program works fine, though.
Acknowledgements:
Ton Plomp and Yair gave us the Code Capture Tool, without which there would be no need to extract snippets in LabVIEW < 2009.
Darin.K showed me how to get a VI from a snippet. Ton helped me improve my implementation.
Change Log:
v1.0.0: Initial release of the code.
License:
BSD
Support:
If you have any problems with this code or want to suggest features:
please go to www.lavag.org and Navigate to
LAVA > Resources > Code Repository (Certified) and
search for the "Abort.vi" support page.
Distribution:
This code was downloaded from the LAVA Code Repository found at www.lavag.org
  • Like 2
  • 3 weeks later...
I didn't look at how the plugin works, but you probably could adapt it to work with a URL - if you feed a URL followed by "[text]" (as in "]http://whatever[text]) into the Datasocket Read primitive, you will get the data in that URL as a string, which you can then either save directly to a PNG file, or copy straight into the clipboard (which I assume is what the plugin wants).
I took Yair's advice, and here's a possible enhancement for the GetSnippet plugin. There's no error-checking to ensure that the selected Text Decoration is in fact a valid URL, or that the resulting file is a snippet-embedded PNG file. Because the snippet decoding is the same for both, I've moved "Save To Buffer" back into Get Decoration (and also it doesn't seem like you need to open the block diagram or front panel, but perhaps I've missed something - haven't coded any RCF plugins before!).
GetSnippet.llb (Saved for LV 8.2)
  • 9 months later...
