[Discuss] UML2LV State Machin Compiler
index.php?app=downloads&module=display&section=screenshot&id=119
Name: UML2LV State Machin Compiler
Submitter: Black Pearl
Submitted: 30 Dec 2009
File Updated: 03 Jan 2011
Category: *Uncertified*
LabVIEW Version: 7.1
License Type: BSD (Most common)
This is a toolkit to convert a state diagram designed with the editor dia into a LabVIEW state machine.
Warning: This uses Scripting: So be aware of dragons, black holes, rusty nails and other monsters. I've only tested it in LV 7.1., got a crash every 2 hours... Bugs and workarounds in newer LV versions welcomed.
Crashes in 8.5. Found the CAR (# 4CJFKTCS)). Edit: Fixed in V 1.0.1
Basic Operation
Create an uml Chart in Dia (it is OpenSource too).
Compile it into a LabVIEW state machine (this will generate an enum based state machine with .vi and States.ctl for the TypeDefed Enum).
Code the States.
Getting started
* You will need to have several OpenG packages installed. Dependencies: appcontrol, file, variantconfig. In order to install these, you need to get the VI package manager from:
http://jkisoft.com/vipm/download/
* For users of LV 7.x you need to get the TRefTraverse.llb from NI:
http://decibel.ni.co...t/docs/DOC-5091
From 8.0 onward they are located under vi.lib\utility
Propably you need to fix the linking from the main vi
* You will need to download Dia:
http://live.gnome.org/Dia
Customizing
* In the Folder LV Scripting you will find the template 'State Machine Prototype Template.vit'. You can modify this within limits to change the state machine that will be generated.
* There is a lot of Documentation with the Code: Check out the documentation folder with the 'Tree VIs' and the uml diagrams (they are surprisingly also made with dia)
* If you have questions, ideas or found a bug, please do not hesitate to contact me! You can do so via PM on LavaG or via my private email on the BD of the About.vi
V 1.0.1:
* Fixed a bug in error handling (Error Handler Close.vi)
* Workaround for the 8.5 crash
* Support for changed Name of CaseSelect
* Started to add support for StarUML
Happy New Year
Roadmap (unsorted):
* Extending the set of verification plugins
* Loading/Parsing for StarUML/XMI
* Creation of String based State Machines
* Make it available for newer LV versions (see this scripting question)
* Handling of orthogonal states
* Converting Notes to Comments on BD
* Converting Transition Events/Guards to whatever
* Write an easy tutorial
Felix
  • 11 months later...
I looked through this tool. Looks interesting, but very similar to the state-chart module. I tried to use the "Replace - no attributes" method, but, it always failed for me in LV8.6. Replacing to "Replace" and the "Params" disappeared, but everything worked after that. Learning how it parses Dia took some experimented, but, worked great when I got used to it. It is definitely pretty quick, and that is one point against the state-chart module.:thumbup1:
