Filename too long in build
Cross posted here.
So I just tried a build in 2009 and got a curious error
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 6 occurred at Create Folder in Create Directory Recursive.vi->AB_Destination.lvclass:Create_Destination.vi->AB_Build.lvclass:Create_Destinations.vi->AB_Application.lvclass:Create_Destinations.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: Generic file I/O error.
NI-488: I/O operation aborted.
C:\Projects\VI Engineering\Software Products\1-09-xxxxx - VI Engineering - Hardware Explorer\Engineering\5 - Release\Executable\VIE Hardware Explorer\VIE Hardware Explorer.exe\LabVIEW 2009\user.lib\_VIE Internal Reuse Library\_vie_lib_dialog_&_user_interface.llb
Due to operating system limitations, LabVIEW cannot create the folder because its complete path contains too many characters.
The files that it's complaining about are going to be inside the exe, so why is it an issue? Surely the filename length check should stop at "C:\Projects\VI Engineering\Software Products\1-09-xxxxx - VI Engineering - Hardware Explorer\Engineering\5 - Release\Executable\VIE Hardware Explorer\VIE Hardware Explorer.exe", which is well under the Windows filename length limit, right?
Even curiouser - changing the "Advanced" build option "Use LabVIEW 8.x file layout" seems to fix the issue...
Nothing odd about that, I was just going to post that's your solution. Using the 8.x layout means it won't have sub folders within the EXE, which prevents you from hitting that all important 250-ish character limit in Windows.
I understand why this is happening (LabVIEW is struggling with the filename length limitof temporary files during it's build) - but I still think that has nothing to do with me - shouldn't it just build somewhere further toward the root (in, say, a temporary location? These files are, afterall, temporary).
This error 6 is actually a major pain in the behind when building executable in LabVIEW 2009.
I think that LabVIEW should be smarter about it and detect when the path is too long and if necessary rename/relocate the offending VI(s) so it just worked. For most people this solution would be ideal.
For people doing some more fancy stuff like calling VI dynamically by path in the build executable, a log file (containing the original and new VI name/path) should be created.
At the very least, the error message should be improve to point the person attempting to build the executable in the right direction ("Generic file IO error" is really not descriptive enough).
PJM
I was using VIPM once and had an issue with too long of a file path and it couldn't build the package. When I reported it to Jim his response was one that I should have expected.
I don't remember the exact verbiage but it was basically that this character size limit should be handled by Windows first, and then if Windows doesn't handle it properly then LabVIEW should generate the appropriate error. He then went on to say that if Windows and LabVIEW both don't do any thing about it, then it was VIPM's responsibility to notify the user. With that response I accepted the fact that this bug is larger than just an application, and is larger than just a programming language, and that Windows should generate the appropriate error, which should propagate to LabVIEW.
P.S. Sorry Jim if I butchered what you said, I'm going off of memory here.
And I completelly agree that Generic File I/O not very helpful.
Exactly. IMHO LabVIEW is having a problem during it's build, not me. LabVIEW created the issue by trying to do stuff out of bounds, not me. Sure, I can make changes to my code to work around the problem, but that's exactly what that is: a workaround, not a solution.
I beleive this is a bug. Anyone from NI care to comment?
