[CR] UI Tools expansion pack: Vista style
index.php?app=downloads&module=display&section=screenshot&id=122
Name: UI Tools expansion pack: Vista style
Submitter: Francois Normandin
Submitted: 10 Jan 2010
Category: User Interface
LabVIEW Version: 2009
License Type: BSD (Most common)
UI Tools Expansion pack: Vista Style controls v1.1.0.4
Copyright © 2009-2015, François Normandin. (LabVIEW controls)
Copyright © 2003-2004 David Vignoni. (NUVOLA ICON THEME FOR KDE 3.x)
All rights reserved.
Author:François Normandin
Contact Info: Contact via PM on www.lavag.org
LabVIEW Versions:
Created with LabVIEW 2009
Dependencies:
Description:
This package contains Vista-style buttons without text.
Includes:
- Set of Vista-style controls
- Based on Nuvola icons (see attached LGPL license)
Instructions:
After installing package with VIPM, refresh palettes if VIPM is not set to refresh automatically.
Use palettes.
Known Issues:
Acknowledgements:
David Vignoni (Icon King) for the Nuvola Icon Theme
Change Log:
v1.1.0.4: Fixed palettes with "?" icons due to control name collisions
v1.1.0.2: Migrated package to VIP, Moved controls to vi.lib, LV 2009
v1.0.1: Removed a menu file that showed up incorrectly in the functions palette.
Linked the Point & Double Point Arrows palettes to the Arrow subpalette.
v1.0.0: Initial release of the code. (8.6)
License:
Distributed under the BSD license.
Nuvola icons are LGPL licensed. Keep Nuvola Icons license with distributions.
Support:
If you have any problems with this code or want to suggest features:
please go to www.lavag.org and Navigate to the discussion page.
Distribution:
This code was downloaded from the LAVA Code Repository found at www.lavag.org
  • 1 year later...
Certified 1-24-2010
Moved to UI Group
François,
could you alter the set to move the boolean text ouside of the boolean image?
post-2399-0-95684000-1301321137_thumb.pn
I have created a screencast on this issue.
<object id="scPlayer" width="632" height="323" type="application/x-shockwave-flash" data="http://content.screencast.com/users/TonPlomp/folders/Jing/media/ecf08f20-602b-446c-8a5e-73f7e46c7ce7/jingswfplayer.swf" > <param name="movie" value="http://content.screencast.com/users/TonPlomp/folders/Jing/media/ecf08f20-602b-446c-8a5e-73f7e46c7ce7/jingswfplayer.swf" /> <param name="quality" value="high" /> <param name="bgcolor" value="#FFFFFF" /> <param name="flashVars" value="thumb=http://content.screencast.com/users/TonPlomp/folders/Jing/media/ecf08f20-602b-446c-8a5e-73f7e46c7ce7/FirstFrame.jpg&containerwidth=632&containerheight=323&content=http://content.screencast.com/users/TonPlomp/folders/Jing/media/ecf08f20-602b-446c-8a5e-73f7e46c7ce7/2011-03-28_1540.swf&blurover=false" /> <param name="allowFullScreen" value="true" /> <param name="scale" value="showall" /> <param name="allowScriptAccess" value="always" /> <param name="base" value="http://content.screencast.com/users/TonPlomp/folders/Jing/media/ecf08f20-602b-446c-8a5e-73f7e46c7ce7/" /> Unable to display content. Adobe Flash is required.</object>
  • 2 months later...
François,
Ton,
I haven't seen your post before today. I'll work on it, hopefully this week-end.
Hi
Can You tell me that How you create the image file to create such control. ?
It really work for me.
Regards
Prabhakant
Hi Prabhakant,
you can install the "Control Class add-on" and it gives you an API for doing what you want. There's also a small program you can launch from the Tools menu that gives you an interface for it.
There are some videos in the discussion thread.
François,
Hey Ton,
I made a quick fix VI. It should move the boolean text to thye top right corner, outside of the control. Also, it will unlock the boolean text so you can move it.
It will correct the whole VistaStyle Buttons hierarchy in the UI Tools folder.
Most likely, I will not have time to make the modification to the set and rebuild the package during the week-end...
François.
CorrectBoolTextPosition.vi (saved for 8.6)
  • 1 year later...
Hello François,
I have issues with UI tools expansion packs.
The controls don't show up in the editor.
I see the issue in LV 2011 and LV 2012
This are my installed packages
post-2399-0-06243300-1353168544_thumb.pn
Here's how it looks:
Debugging shows that:
<vi.lib>\addons\LAVA\controls_lava_lib_ui_tools.mnu
should point to:
<user.lib>\_LavaCR\UI Tools\
Attached is a fix for this.
controls_lava_lib_ui_tools.zip
  • 2 years later...
  • 4 weeks later...
