[CR] UI Tools addon: Tree & Tagging
index.php?app=downloads&module=display&section=screenshot&id=125
Name: UI Tools addon: Tree & Tagging
Submitter: François Normandin
Submitted: 10 Jan 2010
File Updated: 16 Feb 2010
Category: User Interface
Version: 1.0.4
LabVIEW Version: 8.6
License Type: BSD (Most common)
UI Tools Tree OOP Add-On v1.0.4
Copyright © 2009-2010, François Normandin
All rights reserved.
Author:François Normandin
Contact Info: Contact via PM on www.lavag.org
LabVIEW Versions:
Created and tested with LabVIEW 8.6
Dependencies:
lava_lib_ui_tools >=1.0.36
Description:
This package contains classes for manipulating Trees with some enhanced features.
It consists of a set of VIs to create tree objects and associating tags with data in a variant format.
Includes:
- includes some icons from FamFamFam (see license in _Symbols directory) for demo purposes. You do not need these icons if you use the Tree OOP classes in your work.
Instructions:
After installing package with VIPM, refresh palettes if VIPM is not set to refresh automatically.
You will find the palettes in the UI Tools functions palette (user.lib)
Known Issues:
- No drag and drop functionalities included. You'll have to do that on your own if wanted. (for now anyway)
- Arrays will be shown has a succession of Unnamed items. Recursive VI provides a way to put it on
a single line within brackets, but has been removed to provide backward compatibility to 8.6. An add-on
will be posted for LV 9.0+ users.
- The Children & Parents Symbols synchronization works only for Symbol indexes 1-2-3 (True-False-Mixed).
- When adding an item on the same level as an existing one, it gets added in front. Expected behavior would
be to have it added afterwards.
- Modifying a child's data does not recursively modify the parents' data (cluster variants). This will
become obvious once you try the framework... This functionality will be kept in my mind for future improvements.
Acknowledgements:
Norm Kirchner from which I got some tricks in his Tree API (see LAVAG.ORG)
Change Log:
v1.0.4: Solved problems with hardcoded path for symbols installation. Affected primarily installations on 32-bit
Windows systems.
v1.0.3: Initial release of the code. (LV 8.6)
License:
Distributed under the BSD license.
Support:
If you have any problems with this code or want to suggest features:
please go to www.lavag.org and Navigate to the discussion page.
Distribution:
This code was downloaded from the LAVA Code Repository found at www.lavag.org
  • 2 years later...
I just installed this package into LV 2011, and the palettes weren't shown anywhere. VIPM couldn't find them, either. I looked around and found all the code and the .mnu files in <user.lib>\_LavaCR\UI Tools, so I just manually added functions_lava_lib_ui_tools_treeoop_addon.mnu to my palettes. It looks like this UI Tools addon needs to be coordinated with the others so each can safely install its own palettes without stomping on anyone else's.
Very nice tool, by the way!
Update...
To add the addons under the "LAVA>>UI Tools" palette, I've needed to create a UI Tools palette package that will install through LVTN. My submission has not been done yet for this addition, so it will be a while longer before I post an update for the Tree-Tagging addon. Failure to do so would cause multiple UI Tools palettes to appear side-by-side in the LAVA palette, which is terribly bad style ;) . The good news is that is works well and will allow me to integrate more addons that way in the future.
I'll be reviewing all the comments I got on this addon, make modifications and tests, and I'll submit it whenever I'm through with the LVTN submission. Since your solution works in the meantime, I'll leave it at that for now.
