svn:needs-lock properties
How do you set the svn:needs-lock properties for use in a Lock/Unlock model in TortoiseSVN?
You can set it repository wide (I think that only works for new items?), or set it on a file-by-file basis (right click on the file, TortoiseSVN, properties, New..., property name = svn:needs-lock). Our IT dept has a script that runs after TortoiseSVN install that makes our clients add the needs-lock property to all items added to the repo - not sure if I can share that, but let me know if that's what you're asking for.
I have tried to search for this but have found many broken links.:frusty:
Thanks
Dan
Add these properties to C:\Documents and Settings\<username>\Application Data\Subversion\config
[miscellany]
enable-auto-props = yes
[auto-props]
*.vi = svn:needs-lock=yes
*.ctl = svn:needs-lock=yes
*.vit = svn:needs-lock=yes
*.ctt = svn:needs-lock=yes
*.rtm = svn:needs-lock=yes
*.llb = svn:needs-lock=yes
*.lvproj = svn:needs-lock=yes
*.lvlib = svn:needs-lock=yes
*.lvclass = svn:needs-lock=yes
Now, all of these file types will get created with the lock enabled - I think - it's been a while since I looked closely at this
Mark
