External code to act on a LabVIEW ActiveX event
Hi folks,
Are there any examples showing how to write a LabVIEW executable which can act as an ActiveX Automation Server and support event callbacks from other languages ? e.g. within say a C# or .NET program, I want to do the reverse of what you see in the LabVIEW example here:
C:\Program Files\National Instruments\LabVIEW 8.6\examples\comm\axevent.llb\ActiveX Event Callback for Excel.vi
I would like an external client's callback code (accessing my LabVIEW ActiveX automation server) to be executed when I programmatically initiate the event from my LabVIEW code
regards
Peter
OK, so rewording my situation and question.
I have a LabVIEW program with ActiveX Server enabled. Properties and methods can be accessed fine from other programming languages. (specifically a C scripting language used by Test Complete).
How do I fire an ActiveX event from the LabVIEW side which subsequently will cause some callback code to run in the other language.
Essentially I want to do the reverse of what you see in the LabVIEW example here:
So instead of the NewWorkbook event coming from Excel causing "NewWorkbookCallback.vi" to run , I will be (programatically) firing my_own_custom_event from my vi causing some code to run in the other language.
regards
Peter Badcock
Product Development
ResMed Ltd
Perhaps what I am trying to do is not possible.
If one opens up the example I referred to at [2] , Right Click on the Automation refnum constant and "Select ActiveX Class" "Browse" and navigate to the type library file (*.tlb) created by the LabVIEW Application Builder (for a particular EXE you create - mine is named HelloWorld), you will find it only contains properties and methods - it does NOT contain events.
Is that a limitation of LabVIEW ? Can LabVIEW not export events into type libraries ? (at least that is what is suggested in the help file [1]).
I don't want to register for events from other applications, I want to register for events from a LabVIEW application (albeit eventually from another programming environment). I cannot seem to build a LabVIEW application which exports events into its type library.
regards
Peter Badcock
Product Development
ResMed Ltd
[1]
Enable ActiveX server
—(Windows)
so the application can respond to requests from ActiveX clients. The functionality of the ActiveX server in the application is a subset of the LabVIEW ActiveX server. When you build an application myapp.exe, Application Builder also creates an ActiveX type library myapp.tlb. The type library defines an application class and a virtual instrument class and exports both Application
and
and VI
and
. When you distribute the application, include the type library with the executable file.
[2] C:\Program Files\National Instruments\LabVIEW 8.6\examples\comm\axevent.llb\ActiveX Event Callback for Excel.vi
