Create Typedefs from C-header file #define
Bernd F
Hy 2 @ll.
I created some code with typedefs.
These typedefs i created manualy from #defines and typedefs of a headerfile.
Like:
#define LENGTH_FW_REVISION 8 /* including terminator */
typedef struct FwRevision
u_16 result;
c_8 string[LENGTH_FW_REVISION];
} FwRevision;
typedef struct RspGetFwRevision
FTRspMsgHead common;
FwRevision revision;
} structRspGetFwRevision;
Every time the header-file changes i had to modify the typedefs manualy.
Had someone the same problem and did some concept-VIs ? or
Is there somewhere a Demo-VI, i didn't found?
How to create a Cluster with scripting?
Hints or links will be fantastic, too.
Thanks a lot.
Bernd
I'm just playing with SWIG, whuch is able to parse C/C++ headers and create XML with description of all types and functions. From such XML it should be possible to programatically create typedefs and even wrapper VIs using scripting. I have no usable results yet, but it is promising - I want to use it to automatically create C wrappers for C++ DLLs.
Edited by vugie
I've been using a parser for quite some time to create typedefs. It doesn't pars C/C++ header files since it was designed to pars excel created text files for high channel count digital and analogue IO.
The short answer is yes you can automagically create typedefs (they must not be in memory when you update them) and you don't need to use scripting.
Here is a snippet that shows updating of the typdef.
Hy 2 @ll.
Thanks a lot.
Bernd
I am working on an extension of my "Variant To Control" to convert a typedef struct or enum to a LabVIEW control. Here's a beta version of the code:
ArrayToEnum.llb.
Use the 'Struct to Control' VI.
The actual code is in the 'Struct to Variant'. Modify to your needs.
ArrayToEnum.llb.
There is a pw on the "GetContorl From Type Descriptor_A2E.vi ...
