SciWare GOOP Developer, whether or not reentrant?
Why don't you just open the VI and have a look in its properties dialog?
Also, note that since it includes a write, it probably only matters if it's reentrant if you're working on two different objects at the same time, as presumably the framework will lock the cluster if you're working on a single instance.
