How to split a string to decimal?
I'm a newbie with labview.
I use PIC microcontroller read data from TPA81 8 pixels temperature sensor and then it send all string format via rs232 to LV.
My protocol look like this "@32 33 32 11 44 22 33 44 55". (@ is start bit ,, and number are temperature value)
I want to use this string to display 8 temperature datas in waveform chart, how should I do with this string???
Best Regards,
Edited by lovemachinez
Are you passing the temperature values over the RS232 in an ASCII format or binary? If you are passing them in a binary format, I recommend the String to Byte Array. If you are passing them in an ASCII format, look at the String/Number Conversion palette (it's under the String palette). These can get your string into numbers to then put into the graph.
Thank you very much. But I still have some problem you know, my data is a string format , so how can I split it.
for example, string = "32 22 34 54 31 55 12"
How can I split it to => 32 and 22 and 34 and 54 and ........ to put it into array[0],array[1],array[2],............
Best Regards,
Best Regards,
If the separator (space, tab, comma, etc.) is fixed, you can use the primitive "Spreadsheet String to Array" from the string palette.
