Passing VISA resource name
I am using the "open VI reference" to call a vi like a pop-up window. like shown:
In the vi that I am calling, "Debug_Output_Display.vi" I am connecting to a com port. I would like to be able to specify which COM port to choose.
This is all part of a much bigger program that has one front panel where the COM port is selected.
How can I pass this information to the "Debug_Output_Display.vi"?
I am not sure how to do this?
Any help would be appreciated.
Thanks
Jamie
Hi Jamie,
Among other things, I'd suggest initializing a functional global variable with the COM port value you want in your main program, and then access it from your dynamically called VI.
You could also use the "Control Value: Set" method (VI Server) but that doesn't scale well since it's a methodcalled by label text... Change the label text in a future version of "Debug_Output_Display.vi" and you break your functionality without any way to trace it with a broken arrow.
