Passing Labview Cluster to Structure in DLL
Your data cluster contains 9 elements, but the prototype indicates it's only 8 elements. So, you've got one too many elements in your cluster. Also, have you changed the datatype for the NType element to U8, as well as the individual elements of the data cluster?
It did't help.My problem is to pass Cluster to Dll structer (not pointer to structer)
But are you sure that you have to pass the parameter as pointer? Did you try to pass the cluster without converting it as pointer?
I am pass cluster (not pointer to cluster)from Labview to DLL ( function prototype in DLL is "uint32 Function_name(struct OutData)" ) but I think that I pass pointer to cluster from Labview to DLL by Call Library Function window (see attachment pic.)
post-9707-095888300 1279624696_thumb.jpe
Why are you trying to pass a pointer to a structure? The function prototype uint32 Function_name(struct OutData) clearly does not indicate that you're supposed to pass a pointer to a structure!
Also, you seem to be dealing with a C++ DLL, as the name mangling shows. Please review the articles on the NI site and in the LabVIEW Help regarding calling C++ DLLs and name-mangling issues. If you are trying to call other functions you may not be able to see them due to the name mangling that occurs with C++ DLLs.
Edited by Saverio
How I must configure Call Library Function Node in Labview for pass stuct OutData from Labview to DLL(The function prototype : uint32 Function_name(struct OutData) )?
I am try 2 option:
* 1 option:
I am pass cluster.
Call Library Function Node configuration:
Type: Adapt to Type
Data format: Handles by Value
I am bild cluster whith
u32 CobID;
u8 NByte;
u8 array [8];
u32Time;
The all data pass wrong
* 2 option:
I am pass 4 variable:
u32 CobID;
u8 NByte;
u8 array [8];
u32Time;
CobID
Type: Numeric
Data type: U32 int
Pass: value
NByte
Type: Numeric
Data type: U8 int
Pass: value
array
Type: array
Data type: U8 int
Pass: array data pointer
Time
Type: Numeric
Data type: U32 int
Pass: value
The CobID and NByte were correct but array and Time were wrong.
I am can't change the DLL. I am start work with Labview 9.0 and now its did't crash.
