Bug / error / feature ?
I want to be able to add custom decorations (that are saved as template) from palette to my vi:s. I use this for example when I want to add a certain front panel look (legends, signatures etc.) to vi's I edit.
This is how it goes when I use version 6.1
I have edited palettes. Icon at palette points at the template directory.
When an icon at palette is changed to type "Merge VI", the front panel decorations appear to my vi even if the diagram view in the template is empty.
This is not the case with LV version 7.1 or at least it has changed.
If I do have something in diagram view, there is no problem, the decorations come up as they should.
I think it is too early to classify this as a bug but this is for sure a change from earlier version functionality.
