Check for System control
g_sures
Thanks a lot francois. Is it possible to get the data type from that ID, or we need to have a look up table?
Regards,
Suresh Kumar.G
For datatype, Jon made good suggestions.
For the styles, you'll need to create a look-up table.
This "Style ID" will discriminate between System style, classic and modern... but I'm sure that the ID will change between Boolean, Combo Box & Numerics. If you want a universal look-up table, you should consider using scripting to create it: that's another question. ;)
