Disabled & Grayed Out doesn't support transparency
  • 3 years later...
Just to add to this, in case someone else also finds this thread while googling about the problem, the "Grayed Out" seemingly applies an alpha mask that is of the same color as the natural background of the widget.
Has anyone discovered a way to reimplement the grayed out effect?
Well, in typical Hooovahh fashion I have a quick and dirty solution.  You could set the control to be not visible, and instead make a picture control visible that is in the same location as the control but have a picture constant of the way the control should look when greyed out.
