Front panel with round corner
In case I don't find anything on the website of ICON technologies.
I was thinking about a workaround:
I get the picture of the content behind the window and I put a picture control behind the round shape of the corner.
So you have the impression the window stop there but it doesn't.
Do you think it's possible ?
Hi Jonathan,
I don't know which solution you chose, but I meant to put this example together earlier... just didn't find the example code I was looking for.
The code below is taken from John Lokanis, see this topic. Anyway, I put up this example.
playing with Make Window Transparent.zip
<object id="scPlayer" class="embeddedObject" width="1090" height="628" type="application/x-shockwave-flash" data="http://content.screencast.com/users/normandinf/folders/Jing/media/ce6b4f99-a9d6-40d3-812d-4a21bc6d3f07/jingh264player.swf" >
<param name="movie" value="http://content.screencast.com/users/normandinf/folders/Jing/media/ce6b4f99-a9d6-40d3-812d-4a21bc6d3f07/jingh264player.swf" />
<param name="quality" value="high" />
<param name="bgcolor" value="#FFFFFF" />
<param name="flashVars" value="thumb=http://content.screencast.com/users/normandinf/folders/Jing/media/ce6b4f99-a9d6-40d3-812d-4a21bc6d3f07/FirstFrame.jpg&containerwidth=1090&containerheight=628&content=http://content.screencast.com/users/normandinf/folders/Jing/media/ce6b4f99-a9d6-40d3-812d-4a21bc6d3f07/transparent%20panel.mp4&blurover=false" />
<param name="allowFullScreen" value="true" />
<param name="scale" value="showall" />
<param name="allowScriptAccess" value="always" />
<param name="base" value="http://content.screencast.com/users/normandinf/folders/Jing/media/ce6b4f99-a9d6-40d3-812d-4a21bc6d3f07/" />
<iframe type="text/html" frameborder="0" scrolling="no" style="overflow:hidden;" src="http://www.screencast.com/users/normandinf/folders/Jing/media/ce6b4f99-a9d6-40d3-812d-4a21bc6d3f07/embed" height="628" width="1090" ></iframe>
</object>
  • Like 2
  • 1 month later...
Hello everyone,
With the Region Functions from the Windows API, you can give the shape you want to the window (such as the shape of the United States, see area examples.lvilb).
For more information: http://msdn.microsoft.com/en-us/library/dd162915 (v = VS.85).aspx
In the zip file there is a VI for of all Windows API Region Functions. Have fun!
Jonathan Borduas
Windows API - region functions.zip
Hi Jonathan,
</object>
Hello,
In your application, if I show title bar and don't want to show close button. How to do this? Thank you!
Hello,
You might want to make it "unclosable" by the user. Look at the VI Properties "Windows Appearance" tab and uncheck the "Allow User to Close Window". I don't know if that will work as you intend it to work...
Hello,
I already uncheck "Allow User to Close Window", but it just show grayed out. Is it possible shows as attached image? Thank you!
