Update Legacy DAQ to DAQmx equivalent
jimc1041
I am in the process of converting an old test application that uses Legacy NI-DAQ driver function in LabVIEW to use an equivalent set of DAQmx driver functions. The app uses a PCI-6024E card and synchronizes the AI and AO calls with hard ware signals. It also uses the old DAQ-occurances to time the AI read and AO write functions. I'm not sure what the DAQmx equivalent of the old DAQ-occurance functions are. I have posted on the NI forums showing BD segments for the main DAQ VI. [cross post --- http://forums.ni.com/t5/Multifunction-DAQ/Update-Legacy-DAQ-sync-d-AI-AO-to-DAQmx-equivalent/td-p/1314635] Any help would be appreciated.
Thanks,
Jim C
