Global2FGV Transformation
Original idea by SteveChandler
Now available for beta testing.
Developed in 7.1, should run in any newer version.
License: BSD, © Felix Schubert
Dependencies: OpenG, included with suffix
Instructions:
Unzip attachement
Start Globals2FGV.llb and run it
Select Global Variable VI -> Demo/Demo Global.vi
Select Top-Level VI -> Demo/Demo VI Using Global.vi
Select FGV Target Folder -> Demo
Open Demo/Demo SubVI using global.vi and Demo/Demo VI Using Global.vi
Press the transform button
Take a look at the VIs mentioned above and inside the FGV Target Folder
Customization: Change the VIs in the templates folder.
Known issues:
* Some references are not closed
* Errors when closing invalid references in shutdown can be surpressed
* The placement/rewireing doesn't support the smaller footprint of newer LV versions
* The FGV target folder isn't validated
* The transformed VIs are not saved and not presented to the user
Wishlist:
* Use wrappers for Get/Set
* Display locations of global references
Your feedback and bug-reports are welcome.
Felix
Global2FGV.zip
"An error occured loading VI 'Demo VI Using Globals.vi'. LabVIEW error code 6: Could not load bloack diagram." - LabVIEW 2010.
Thanks, I have a NI CAR for this behaviour. You can select Demo SubVI using Global.vi as Top-Level VI instead. All you miss is to see that it's recursing through SubVIs as well.
Felix
