Hi!
I would like to write a code, what is able to find the ProgramFiles\National Instruments\Shared - Folder. This folder is selectable during installation.
This code will be placed into my exe, and Installer.
So, When the user install my applicaton, and select a path where my application and National Instruments Runtime will be installed, my app will search for the National Instruments\Shared path.
Is there any tricky way for that, or I have to seach whole computer, so I will have a lot of premission error.... :(
Hi!
Most likely it's location is stored in a key in the registry in a National Instrument specific subtree.
I would like to write a code, what is able to find the ProgramFiles\National Instruments\Shared - Folder...
Check out [LabVIEW]\help\_exfinder.llb\get NI shared folder path.vi. It's password-protected (makes a callback into LabVIEW.exe), but it does the job.
  • Like 2
Will this vi work if I don't have LV development? I mean, I wanna create an installer, LV09 RTE will be included. When I install this app, will this VI returns the Shared folder?
Do you have any experience or shall I make a test on it?
Thanks in advance!
Edited by durnek60
