Connectivity between setups
Hello,
I have a setup with a PC with LV10 and a DAQ card that receives stimulus from sensors
Assuming that there are 3-4 of these setups, how can I:
1. View from any one setup the processed data from the other setups
2. View/display the processed data from all the setups to a PC with LV and no DAQ on it
3. Make each setup receive and send data to the other setups
Thank you in advance,
You could:
Create an acquisition application and run multiple instances of it (on your 3 or 4 computers).
Have each of these publish the data.
Create a View application that runs on another machine. The View subscribes to the data published by the other applications.
Notes:
1) Networked shared variables will work great for this. I recommend putting the published data for each acquisition system in a uniquely named library.
2) If you want to send a message from the View to a specific instance of the acquisition applications, you might consider including an instance identifier in the message. This probably won't be necessary, however, if you create libraries with unique names.
Paul
