Validate IPv4 and IPv6 adresses
Wouter
VI Name:
IP Validation
Total VIs:
strpos.vi, strrpos.vi, substr_count.vi, valid_ipv6.vi, test,vi, unittest.vi, ip2long.vi, long2ip.vi, valid_ipv4.vi
Description:
I saw in the svn of OpenG that there was a candidate for IP validation. But however I think I have a better one. One for IPv4 and one for IPv6, credits for the IPv6 algo goes to http://crisp.tweakbl...d-caveats).html
Note:
Blockdiagram:
What are you thoughts on this VI?
  • Would you like to see such a function in OpenG?
  • Can you optimize the code?
  • In which package should it be included?
  • Should it be rejected?
-edit- ups I forgot to set the unittests data I inputed in the control as default value... well you can now enter them by hand.
$unitTests = array(    '2001:0db8:0000:0000:0000:0000:1428:57ab'    => true,    '2001:0DB8:0000:0000:0000:0000:1428:57AB'    => true,    '2001:00db8:0000:0000:0000:0000:1428:57ab'    => false,    '2001:0db8:xxxx:0000:0000:0000:1428:57ab'    => false,    '2001:db8::1428:57ab'    => true,    '2001:db8::1428::57ab'    => false,    '2001:dx0::1234'    => false,    '2001:db0::12345'    => false,    ''            => false,    ':'            => false,    '::'            => true,    ':::'            => false,    '::::'            => false,    '::1'            => true,    ':::1'            => false,    '::1.2.3.4'        => true,    '::256.0.0.1'        => false,    '::01.02.03.04'        => false,    'a:b:c::1.2.3.4'    => true,    'a:b:c:d::1.2.3.4'    => true,    'a:b:c:d:e::1.2.3.4'    => true,    'a:b:c:d:e:f:1.2.3.4'    => true,    'a:b:c:d:e:f:1.256.3.4'    => false,    'a:b:c:d:e:f::1.2.3.4'    => false,    'a:b:c:d:e:f:0:1:2'    => false,    'a:b:c:d:e:f:0:1'    => true,    'a::b:c:d:e:f:0:1'    => false,    'a::c:d:e:f:0:1'    => true,    'a::e:f:0:1'        => true,    'a::e:f:0:1'        => true,    'a::f:0:1'        => true,    'a::0:1'        => true,    'a::1'            => true,    'a::'            => true,    '::0:1:a:b:c:d:e:f'    => false,    '::0:a:b:c:d:e:f'    => false,    '::a:b:c:d:e:f'        => true,    '::b:c:d:e:f'        => true,    '::c:d:e:f'        => true,    '::e:f'        => true,    '::e:f'            => true,    '::f'            => true,    '0:1:a:b:c:d:e:f::'    => false,    '0:a:b:c:d:e:f::'    => false,    'a:b:c:d:e:f::'        => true,    'b:c:d:e:f::'        => true,    'c:d:e:f::'        => true,    'd:e:f::'        => true,    'e:f::'            => true,    'f::'            => true,    'a:b:::e:f'        => false,    '::a:'            => false,    '::a::'            => false,    ':a::b'            => false,    'a::b:'            => false,    '::a:b::c'        => false,    'abcde::f'        => false,    '10.0.0.1'        => false,    ':10.0.0.1'        => false,    '0:0:0:255.255.255.255'    => false,    '1fff::a88:85a3::172.31.128.1' => false,    'a:b:c:d:e:f:0::1'    => false,    'a:b:c:d:e:f:0::'    => false,    'a:b:c:d:e:f::0'    => true,    'a:b:c:d:e:f::'        => true,    'total gibberish'    => false);
ValidateIP.zip
Edited by Wouter
Having only gleaned a little from the VIs names, I presume it uses string/token-based analysis to validate the strings as an IP address. There exists the the "String to IP" and "IP to String" LabVIEW nodes, I wonder if these would be faster to use for IPv4 addresses? There may be OS-specific calls which are faster,
In general, though, I think that these would be helpful only in data validation scenarios, rather than actual networking scenarios - if you plug in an ill-formed address, the networking node will return the correct error and you should handle it downstream.
Also, your IPv6 reference link got mangled.
