Digital display
Doesn't turning off Y scale autoscaling work? You could then programatically set the top and bottom shown plot.
N.B. I haven't tried it but IMHO it should work this way.
cherrs, Alex
2370[/snapback]
I will give that a try, but here is a picture of what I mean. Anyhow, apparently I can get it to align if I resize the font. The problem is that it gets too small to read. :wacko:
post-333-1098199532.gif?width=400
Well fellas... I tried your suggestions, but it didn't work as plan :wacko: .
Also, Resizing the legend would just add or remove elements because each legend element has a predefined height size, for example 21. The size of four elements would be 84.
If we can pre define the individual height of the legend element, then we could adjust it.
Any suggestions?? Maybe there's something I can set in LV??
Thanx.
Why not just increase the Font size of the legend only? Seems to work for me.
post-2-1098404278.gif?width=400
2434[/snapback]
I did try this before you posted :shifty: Although I can't get the same solution. :headbang:
Hmm.. Guru's like you always seem to have a solution :worship: I'm not worthy
I was just wondering how you manage to get the font size to change with
the object(legend item) to rescale it's size?? It doesn't work for me ctrl +++?? maybe a dumb question :blink:
thanx
