Typecast - What does "*(type *) &x" mean?
&x is the address of x
(type *) is a coercion to pointer to type
* is dereferencing value at x treated as type.
Thanks! That syntax was teetering just above my level of C syntax comprehension (rather, tolerance? :shifty: )
There are few others descriptions of terminals understandable only for text programmers (if not for C-programmers strictly):
x-y*floor(x/y) - reminder
r*e^(i*theta) - complex number
s?t:f - select
NaN - not a number
Another notable carry-over is the use of "[]" to signify "array". You can find this C syntax many of the primitive icons themselves, not just the terminal names.
(And just for the record: generally, it makes sense to reuse these conventions in LabVIEW rather than invent new analogies. The typecast example is one of the few instances where I might consider breaking this convention, just because the syntax is confusing)
Absolutely! Another reason I like to use the OpenG comment, rather than other arbitrary free text labels.
Ah, this is actually one I don't like. The syntactic significance of /* ... */ is moot in LabVIEW - what else could a free label be used for on the block diagram but to comment? I particularly dislike the color contrast chosen for the OpenG comment. I see no value-add except having more colors on your BD.
I whole-heartedly embraced the square-bracket array notation (but rarely find cases where I think its necessary) and think that the typecast terminals are only misleading in that they use the & and * operators in a language that's almost exclusively by-value. I remember the first time I read that terminal, I got a little warm and fuzzy feeling for knowing exactly what it meant, though. Ah, C, I miss you sometimes...
Well then you're a stupid poo bum doodie head.
Lots of things - like custom classes of tags that cen be read by scripting nodes (eg: run a report that scans free text labels that are a particular color or start with a particular tag to show all those "fixme" notes).
It wasn't as much chosen for OpenG, it's an already accepted standard in multiple programming languages - to make it something else is unintuative.
Elegantly put. I redact my comments.
This sounds like a weak case to use scripting to dig through property nodes. ;) Personally, sticking a "TODO:", "DEBUG:", or "FIXME:" just as easily facilitates finding these comments without requiring that the free label be of any specific format. I recognize that it is a standard, but argue that it's simply one that does not apply.
Keep an eye on your svn logs, I'm going to start changing all of your comments. :D
  • Like 2
Can anyone answer the question: What does "*(type *) &x" mean?
It means a LabVIEW developer momentarily forgot that his/her users were not C++ programmers, the tech writer was on vacation, and this was written so long ago that when I asked if we could change it, the answer I got was, "No, that's the label of the terminal, which means someone might be using it in scripting code, and you'll break their code if you change it now."
NaN - not a number
That one doesn't count. That's an IEEE standard definition of the numerical value of Not A Number. That's correct as it stands, not a C++-ism that should have been scrubbed back in the dawn of LabVIEW.
I hate it when mom and dad fight...
At least he's not drinking tonight. "Two beds and a coffee machine..."
* Hah! Take that stupid editor. Try to inline my media files when I don't want you to... grrr...
Edited by Aristos Queue
I added some formatting and expanded it a bit. I was going to come up with an example of using completely different functions in each sub-expression, but got lazy.
Yeah, I think keeping the terms the same as the previous example works. Also, I added "()" for clarity.
