Configuring XControls using an .ini file
Hi. I have a front panel that consists of 30 XControls. Depending on the test each of them has to have different caption and position.
I use an .ini file to read the configuration data and assign it to the specific XControl.
But if I have many Xcontrols i have to create separate Property Nodes and assign the data for every control separately. Is there a way to put this inside a loop so the code uses smaller area of the screen?
In your init state of the XControl you could read the settings from the configuration file and load them.
If the XControl is an initial drop the previous version is different than 0.0.0.0, and you can get the label of the control to read the ini section.
