Position in arrays
Sarah83
Hi!
If I have two arrays with 12 elements of strings and I will like to know if e.g. in both arrays the elements at position 4 are filled in with some values (I can check this with a blank string constant) and all others are blank how could I find out the position four?
I thougt of a case structure in which I will list all possibilities.
Sarah
If you take one of the sting array controls and an empty string constant, wire them both to a 'not equal' operator, the result is a boolean array. Each element of the array shows you if the corresponding element of the string array is filled or not. Now if you check position 4 of the boolean array it shows you whether that position is filled. Do that for both arrays and 'and' the results and you will know, whether both positions are filled.
post-1022-1100526600.jpg?width=400
