GOOP Development Suite v4.5 is released
Hi
I can see at the Symbio home page  there is a GOOP Developmente Suite v4.6 version!
What's the news? 2013 support perhaps?
regards Bjarne
You should be able to download it from symbio.com/goop  (on the lower right side)
But I'm about to release GDS 4.7, this version should be downloadable in the end on this week.
I'll keep you posted.
GDS 4.6 don't have to many exciting stuff, other than 2013 compatible.
GDS 4.7 have a 2013 bug fix and also property node creation (so you can access your object data through property nodes)
Cheers,
Mike
  • 5 months later...
I’m sure we’ll get interface sooner or later to LabVIEW, in the mean time we have to implement it ourselves in different ways.
Here a thread and one example I use: http://lavag.org/topic/10621-interface/
I’ve not documented the Interface class template and how to use it, that comes with GDS.
But here is a quick instruction, this design only makes sense to Referenced Objects.
Add Interface Methods
Create a Normal class that should implement the interface
Add a design pattern: Interface
This is what gets created
attachicon.gifInterface.zip
Cheers,
Mike
Hello Mikael,
I tried to use the interface the way you described, but I am getting an error (invalid reference) and I cannot figure out how to fix this. Could you give me a help with that?
post-15546-0-78121800-1394389983_thumb.p
thanks
Helcio
GOOP DUCK.zip
I did a quick example where the Duck class implements the FlyBehaviour like this (see attached file)
But for the design you are looking for, I would implement it like this:
This soution does everthing you want. Why Interface is used in the design you are looking at (page 22 in Head First esign Patterns), because Interface exists in Java :-)
Duck.zip
Hi Mikael,
I am trying to do the second solution indicated in the picture Interface2.png:
post-15546-0-21769700-1394478882_thumb.p
The reference for the Duck class is invalid when the method PerformFly is executed, then I get the error 1556. How do I do this the right way?
Thanks
Helcio
Duck2.zip
Hi Mikael,
I have been scratching my head......
I have been looking further into the 1556 error in the Duck Main.vi (attached) which claims that the reference is not valid. But if I clear this error, everything works just fine, as the reference refers to an object which exists in memory and the reference seems, therefore, to be perfectly valid:
post-15546-0-47367900-1394560154_thumb.p
The error is generated just after it verifies if the reference is valid using the Not  a Number/Patch/Reference function. I looked in the Help for this function and it says cannot be used to check for the validity of refnums created by Goop Wizard:
post-15546-0-82180000-1394560062_thumb.p
 Is this a bug in Goop?
Thanks!
Helcio
Here is the
Duck3.zip
Hi Mikael,
I built an observer pattern with Goop:
post-15546-0-30509000-1395961492_thumb.p
I basically followed the Weather Station example in the Head First: design Patterns:
post-15546-0-33220300-1395960890_thumb.p
I used the goop's interface template and the interface implement design pattern for the observers, but I think it would also work just fine using  abstract class for rather than the interface. Here follow the the files (Observer Pattern GOOP.zip) and If you or anybody else have any comments, please, let me know.
thanks
Edited by burd
Hi Mikael,
I am trying to build the Starbuzz example in the Head First: Design patterns using Goop. I have had partial success and this vi works:
post-15546-0-29153400-1396045833_thumb.p
However, something goes wrong when I want, for example, double soy or double mocha, etc.
post-15546-0-48887200-1396045851_thumb.p
Could you help me to figure out what is going on?
This is the project containing all classes and main vis: Decorator Patterm with GOOP.zip
Thank You!
Edited by burd
To start, have a look at my solution for the same example :-)
It looks like you just forgot to set the Cost VI to reentrant.
Hi Mikael,
Your solution is very elegant!
I liked that the create vis can be used also to put constructors in it:
post-15546-0-96676100-1396305984_thumb.p
and also I leked the way the class item icon in the  project explorer mirrors the class hierarchy:
blue for Beverage classes, red for condiment classes, frame for abstract classes and full for concrete classes:
Thanks a lot for the solution!
Helcio
  • 1 month later...
Hi Mikael,
I am trying to build the abstract factory pattern with GOOP and I do not know how to check if an object reference is not empty in Labview.
In JAVA this was done like this:
post-15546-0-21293300-1400782570_thumb.p
How can I do this in labview?
If you're using the factory pattern... I expect you'd have flags in the object. The toString function would be an overloaded VI. However... this looks like the example for a decorator pattern. An example of both is at: https://decibel.ni.com/content/groups/large-labview-application-development/blog/2012/01/17/object-oriented-design-patterns-for-labview-that-can-make-your-life-easier
Hi Mikael,
What class type are you using?
If it's a GOOP3 type, you can use the Utility VIs (under Addons->GOOP Utility) GOOPUtil_IsValidReference.vi
Hi Mikael,
I have just read the post, thanks for the tip!
The GOOPUtil_IsValidReference.vi is exactly what I need but unfortunately I use Goop4 classes :(
Is there anything for goop4?
regards
Edited by burd
I'm working on it, you can try this solution, it looks likes it works in 2012 at least.
But I'm not sure if it should work, we better ask NI.
Make sure you convert the number string to U32, not I32 that is the default
Cheers,
Mike
Edited by MikaelH
Hi Mikael,
I have completed the abstract factory pattern. I am sending attached for anyone to look and comment.
I realized that I actually do not need to know the reference to a class is empty. If the class wasn't instantiated, the abstract method  parent class executes (in the method toString in Pizza.class, the parent method of classes Sauce, Cheese, Dough, etc will be called in case these classes were not instantiated) resulting an empty string.
Would be nice to have the tool to know of the class was instantiated, but I prefer to wait until you to complete the Utilities for goop 4 classes, looks complicated.
The files are at https://decibel.ni.com/content/message/75586#75586 because they are too big to upload here.
regards
Helcio
