Labview 2012 SP1?
See here too - http://forums.ni.com/t5/LabVIEW/LabVIEW-2012-SP1/m-p/2304240#M725167
Like Tim said, you should probably not expect new features. If you want new features, you can request to join the LV 2013 beta - http://www.ni.com/beta  or look at the In Development ideas on the IE - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/idb-p/labviewideas/status-key/indevelopment
  • 4 weeks later...
LabVIEW 2012 SP1
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/ssnav:pdl/q/2012/
Note:  For some reason when I loaded the downloads page it did not appear, but searching 2012 and then clicking Clear All fixed this.  Maybe something's cached funny with the browser.
Already a patch for it:
http://joule.ni.com/nidu/cds/view/p/id/3803
After upgrading first to SP1, then immediately applying fix 1 - LabVIEW is no longer able to run without crashing with an access violation:
"Access violation (0xC0000005) at EIP=0x00EFD480"
A common/known issue, or was I just "lucky"?
I've tracked down the crash that came after upgrading to 2012 SP1(f1); it is caused by an add-on installed with VIPM.
Clearing user.lib on its own did not fix it, neither did moving things out of the project folder. But when I removed the add-ons from vi.lib the crash stopped. The funny thing though is that if I then just put back the stuff from user.lib the crash returned.
So maybe there are multiple items crashing LabVIEW (both in user.lib and the other places)...I'll do some more digging.
Has anyone with Developer Suite SSP received DVDs yet with Labview 2012 SP1 on it?
Thanks. --Joe
I have.  I'm not sure when I got it though because I just downloaded SP1 when it come out, and just recently noticed a pack of DVDs with the SP1 release.
I rescind my previous statement. It seems the SP1 download does not include the f1 fix (although it says it does in the Update application).
SP1 version from Update: 12.0.1
SP1 verfion after F1 patch: 12.0.1F1
No crash for me installing the F1 patch though.
Hello everyone,
In general if you are installing a LabVIEW service pack through Update Service and there are existing f patches for that service pack, they will be automatically installed with the service pack. In this case the f1 patch was not installed because it has been taken down temporarily.
  • 3 weeks later...
Speaking of which, just in case there are others of you out there who have 64-bit systems, and have always downloaded the LV installation packages from the web...
The DVDs that NI sends out do *not* have the 64-bit IDE.  If you use the DVDs, you will get a 32-bit install, even on a 64-bit system.  With no apparent warnings -- other than the fact it asks if you want to install into "Program Files (x86)".  Yes, I just learned this one the hard way.
Go here to kudo an idea to add the 64-bit IDE to the Platform DVDs.
