Difference between two dates/times
Hi all,
Trying to work with date and time with this format:
mm/dd/yyyy hh:mm:ss (This is the input I have)
What I would like to get:
Output = (date1/time1) - (date2/time2)
I have to find the way to get the difference between to dates/times and I'm not able to do it in Labview although I'm almost sure that it's possible.
Could you guide me a little bit, please?
Thanks in advance.
Kind regards.
Jose.
:worship:
2817[/snapback]
Hi Jose,
I'm assuming that this is a string input you're dealing with.
If so the 'Scan from String' and 'Date/Time To Seconds' functions can be used to obtain a numeric datetime. Attached vi (LV6.1) is variation of what I use. Convert the strings for the two times and then subtract.
Download File:post-55-1101928881.vi
Hi all,
Thanks in advance.
Kind regards.
Jose.
:worship:
2817[/snapback]
Here is something that might work for you.
post-17-1102798000.png?width=400
Download File:post-17-1102797995.zip
