Adjust XY Scales Individually - Array of Clusters
Hello everyone,
I have a VI that loads an ASCII file and plots each one of the columns on graphs. It works very well but the problem is that the number of columns may vary. Some ASCII files have 3 columns and others have 40.
I made an Array of Clusters and inside each cluster there is a graph that is fed with data from the ASCII file.
I would like to know if there is a way to adjust the scales of the graphs individully. Currently, as you change the scale into one graph, it is spreaded over all graphs in all clusters of the arrray.
This has been already asked before in another forum but I didn't get a solution yet. Actually, I believe that there is no solution for this since elements in a array should share the same properties. Then, I am looking for a workaround.
Thanks.
Dan07.
