Programmation in Labview
BillyJo
Hello
  First of all, sorry for my english because I'm french.
I would change color code in a "intensity chart". I still know I have to use a property node with color table but not how
Friends of labview, thanks very much
2846[/snapback]
Hi BillyJo!
Which color would you like to change?
Do you mean the axis?
Try right click on the chart and in the properties the folder scale. There you can set some colors.
There are colors in the ramp color I want to change and I believe the way is to create a property node in order to modify settings in intensity chart
2852[/snapback]
Hmmm, I'm not sure... create a property node, right click-choose class-vi server-general-gobject-scale-colorscale-colorscale. (my lv version is German, I hope I have written the right headings ;) ) Parallel open the help (click on the yellow "?" in the right corner)
Thanks Sarah and Didier.
Didier, I made what you said: it's ok. But I'm sure there is way to set the 256 colors of the ramp. A array must be created as input in a property node of intensity chart with the property "color table".
If you have an other idea...
2859[/snapback]
I found it :D
There is an examlpe in the lv help!
Search for "create IntGraph Color Table.vi" :thumbup:
