notifier understanding
what im trying to accomplish:
. start count down timer.
. every ten seconds, trigger an event via notifier
. do not interrupt counter while triggering event.
. abort at any time via "abort" button
. finish after 60 seconds
what its doing:
. starts count down timer
. after first ten seconds trigger event
. does not interrupt counter
. will abort at any time
. finishes after 60 seconds
. will not trigger event after first ten seconds
obviously im not using the notifier properly and
am hoping someone here can fix my mistake
with a small amount of explanation on what
i did wrong.
the attached "code/vi" shows what i did.
i also added a .jpg screen capture incase of version issues.
thanks,
robert
post-981-1105124146.jpg?width=400
Download File:post-981-1105123825.vi
The reason the dialogue box only happens once is because it is not in a loop. If you add a loop it should solve this problem.
post-584-1105135420.png?width=400
another problem that I ran across was the send notifier case is true for 10 ticks or 100 ms.
this will send a notification twice with a 50 ms timeout and caused me to have to click the ok button more than once.
3422[/snapback]
thank you for the explanation. i was not aware the notifier need to loop. i had mistakenly thought that if the send notification was looped that would be sufficient. this is the modified version.
robert
post-981-1105381934.jpg?width=400
