Encoder Simulation
Marcos
Hello everybody.
I am actually using a PXI system, with a PXI-6259 and a PXI-6723 boards on it.
I am working on a Quadrature encoder simulator, but it doesn't work as fine as I want. Does anybody has information or an example about how to build an encoder simulator.
Thanks a lot. Muchas Gracias.
Marcos
  • 1 month later...
Marcos,
I have been crawling around the online NI Developer Zone and was able to track down a couple of examples that were developed for the NI-660x counter boards.
The examples linked below use from 3 to 5 counters to implement a simulated encoder. Just look at them and see if you can make your way through it:
Finite Quadrature Encoder Simulator
Have fun :headbang:
:ninja:
