Actor framework simple app with pneumatic cylinder
Hi lab funs,
i am beginner with Actor framework (AF). Could you help me understand how to work with AF?
My app has 5 cylinders ( Gate, Lift, Shift, Grab, Clamp ), 3 Lamps ( Pass, Error, Servis), 2 Locks, Air distributed ( Vent, Sensor ) and HW Start button.
I made class of cylinder with methods ( Init, Move, Check Position ) and i made driver used QMH for this class.
Q1: if i want control 5 cylinders, i must make actor for each cylinder or only one ?
Q2: How i make comunication between actors cylinder and air distributed ( is free-running, every 1s check pressure then go to turn ON or turn OFF and send message to control actor if pressure = false )
THX
QSM-Projekt_Lab2010ver1-01.zip
  • 1 month later...
Hello everybody,
What do you think about this construction:
i have manipulator composite of 4 pneumatic cylinders. I create objects cylinder and manipulator each object has sequence. Cylinder has sequence: check position->desired position->stop & manipul has release->grip->upward->move->level->clamp. Manipul has also 4 parametre for sequnce ( Zon, Lev, Job, Clamp ).
Check my program.
Is it possible this program change to AF ?? Could you tell me how please ??
THX
img-Z13121327.pdf
-----RSV_EM-2001_ver-1-01-----.zip
