Source code location affects execution speed?!?
This is a very strange problem.  I have put together a demo project to demonstrate the speed differences in array vs variant attribute storage methods.  I also included a test of different variant database designs to show some pitfalls.
I first built this project in the following folder on my machine:
C:DevelopmentSourcesandboxVariant Attributes
It seemed to be working well and demonstrating the effects I was after.
I then moved the folder to my desktop:
C:UserslokanisDesktopVariant Attributes
When I opened the project from here, and tested it, the demo ran 1000x faster and no longer demonstrated the effect I was after.
Next I tried moving it to here:
C:tempVariant Attributes
And I got a result closer to the original location but still not the same.
Here is the code: Variant Attributes.zip
Run the VI: "Compare Class Database Storage Methods.vi"
Any ideas what is going on?
BTW: the point of the demo is to show that storing large elements in a variant database is faster if you store DVRs of the elements.  This should avoid large data copies.
Yes, always from inside the project.  I cannot reproduce the 330x result.  This is what I get running outside the project from the desktop:
post-2411-0-33020300-1386715819_thumb.jp
Of course, now I get the same results from all locations.  Must have been something weird about my machine at the time.
(Also running Win7 and LV2013)
Ooh this sounds familiar.
I had some WEIRD performance issues a few weeks back with the divide primitive taking different amounts of time depending on which values it was dividing, and I mean MEASURABLE differences.
Closed the project, re-opened and the issue was completely gone (hopefully) never to be seen again.
It seemed at the time like the math libraries had started going a bit wonky.
As with all problems of this ethereal type (you look at them properly and they disappear) you end up questioning your sanity and have no change of filing a bug report because noone will be able to reproduce it.
Shane.
I also had a similar issue where a simple VI using Variant attribute lookup took a long time to execute if the owning library/class was opened.
The time difference was never measured, but running through ~1000 elements was noticeable slower.
I tracked this down to be an issue with re-entrancy, once I made the VIs reentrant the execution speed was the same regardless of where it was started.
/Jonas
