PATTERN MATCHING; NEED ASSISTANCE
Hello everyone,
i am new to this forum, i am working on a pattern matching project and i require some assistance .
I have made a VI of my own after going through the pattern matching example included in the LabVIEW exmaples.
unfortunately i am getting stuck in the pattern matching of the VI.
i am enclosing the VI that i made and the image that i wish to compare. Initially i wish to compare the image with itself and later try the image with other images.
i shall be grateful if you all can guide me through what i am doing wrong
Thanking in well in advance
Regards
Jalashwa
example.vi
post-50177-0-62113000-1389347340_thumb.j
I would suggest working with the vision assistant to get started.  You can convert the express VI into a regular VI later by right clicking and opening the front panel.  This should get you a good starting point.
Off the bat I'd point out that you don't want to dispose of your references until after processing.  What pattern are you trying to match?
I fear he is trying to detect "Planes" by providing an image of a plane then seeing if the program can detect a plane in another picture.
