set system time
mynock
Hi!
I need to realize a sub-vi that receives a time input and use this data to set current system time. Setting system time must be possible even if user doesn't have administrator privileges, therefore I cannot use directly System Exec.vi to set time using TIME command...
any idea?
thanks in advance!
Hi!
any idea?
thanks in advance!
3812[/snapback]
A snippet of my post to info-labview
Date: Wed, 7 Jan 2004 09:47:54 +0100
On PC-machines the one and only real information about time is available on
RTC-CMOS. You can read this information by OutPort and InPort conversation from
any language. Everything else is hickhacked by OS and software.
OutPortAddress = 70h
InPortAddress = 71h
WriteValue DataRead
00h seconds
02h minutes
04h hours
07h day
08h month
09h year
No lability on this information.
You will communicate down to CMOS!
You can also write to RTC-CMOS
Sorry I can't find the VI at the moment.
Manfred :2cents:
Hi, Mynock! You can programmatically set Windows System Time as explained here:
http://digital.ni.com/public.nsf/3efedde43...54?OpenDocument
But, as you said, if you don't have Administrator or Power User privileges, you can't change system date or system time. You can run your program under a new created Power User account or, if you prefer run your program under a simple User account, you must change the "Change System Time" item in "User Right Assignment" in Windows "Local Security Settings" Console. Here the way to reach it:
Control Panel -> Administrative Tools -> Local Security Policy -> Local Policies -> User Rights Assignment.
Here you can find "Change the System Time" item. You have to add "Users" group to Security Setting List and reboot your machine. Now a simple User account can change system date and system time. I hope it will be useful for you.
Greetings
