System Exec Problems
All,
I have a couple of VIs that I have converted into executables. These executables I am attempting to call from another VI using the System Exec.vi. Unfortunately, the calls work only some of the time on my XP machine.
I get the following error (Error code 2):
Possible reason(s):
LabVIEW: Memory is full.
NI-488: Write detected no listeners.
Moreoever, here's a twist. I can place a File Dialog VI on the block diagram and feed the path it produces after I select my executable into the System Exec.vi and it seems to always work. Below I have an example of the two setups I use (the top setup, the File Dialog created path, always works; the bottom setup, constant path, sometimes works):
So I'm left wondering, is there something about the path that I'm feeding System Exec that may cause it some problems?? I really have no idea and would appreciate any help. :headbang:
Thanks.
post-2-1110249283.jpg?width=400
  • 4 weeks later...
